acl sequence in asa
Answered Question
Dec 29th, 2010
What is the process sequence in an asa with ipsec configuration , for traffic initiated from inside & from outside.
  Remote Host ->  Router -> Internet -> Asa ->Local Host
remote router has crypto acl , Asa has crypto acl and interface acl.
If local host starts traffic via Asa , will it first use the inside interface acl on ASA or crypto acl.
Appreciate if this can be helped with.
Correct Answer by Atri Basu about 6 years 6 months ago
HI,
The inside acl will always be the first ACL to be hit. To confirm you can use the packet-tracer command, this will tell you exactly which process comes into effect and when:
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/p.html#wp1878788
The following image should give you an idea of the exact sequence of operations:
The crypto ACL will be hit immediately before phase 8(Egress Interface).
Atri.
Overall Rating: 4 (3 ratings)
Kureli Sankar Wed, 12/29/2010 - 07:50
  • Cisco Employee,
Inside interface acl, nat 0 acl on the ASA and then the cypto acl on the ASA.
-KS
Correct Answer
Atri Basu Wed, 12/29/2010 - 07:59
  • Cisco Employee,
HI,
Atri.
suthomas1 Wed, 12/29/2010 - 08:42
if inside acl is called in first, then a strange problem in this remote setup is the packet gets dropped due to implicit deny on inside interface list . this comes up during tracer. inspite of the acl having a defined line for the traffic that is required.
below is the list on local interface. Line 2 is meant for traffic which is from host 172.16.100.50 to 10.52.151.81 on a tcp port.
asp capture shows this drop also.
access-list local-access line 1 extended permit ip 192.168.100.0 255.255.255.240 any (hitcnt=0)
access-list local-access line 2 extended permit ip host 172.16.100.50 10.52.0.0 255.255.255.224 (hitcnt=0)
any valuable suggestions for it?
thanks.
Kureli Sankar Wed, 12/29/2010 - 09:30
  • Cisco Employee,
10.52.151.81 is not covered in 10.52.0.0 255.255.255.224
http://www.subnet-calculator.com/
-KS
suthomas1 Wed, 12/29/2010 - 18:20
I am sorry . it was written wrongly.
acl is meant for source 172.16.100.50 to destination 10.52.0.18 on a tcp port
it shows as dropped even if the rule is there. and running logs dont show anything except for capture which says reset.
thanks for your help.
Kureli Sankar Wed, 12/29/2010 - 19:35
  • Cisco Employee,
need the following output:
1. sh run nst
2. sh route
3. sh run access-g
4. sh access-l
5. packet-tracer input inside tcp 172.16.100.50 1026 10.52.0.18 - replace with the port number that the host 10.52.0.18 listens on.
6. enable debug level logging and post that as well
conf t
logging on
logging buffered 7
exit
sh logg | i 172.16.100.50
-KS
suthomas1 Thu, 12/30/2010 - 22:21
Thanks KS & all, this was resolved.
It was found to be an ip addressing problem with server.
