Warning message
ACS 5.1 integration with WLC
Answered Question
Dec 30th, 2010
can some one help me in finding a document for ACS 5.1 appliance, TACACS+ integration (configuration) with my WLC. also RADIUS configuration for clients.
all Wireless controller configuration documents shows only acs 4.x integration.
Thanks in advance
Correct Answer by Federico Ziliotto about 6 years 7 months ago
For 802.X authentication, I don't have any screenshots as of now.
But you can always refer to the following chapter in the ACS 5 configuration guides:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_system/5.1/user/guide/policy_mod.html
Fede
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
Unfortunately there is no official configuration example for this as of now.
You can haowever refer to these screenshots that I took from a lab example, to configure the shell profile and pass it back as a result of the authorization rule.
Hope this helps,
Fede
Overall Rating: 5 (4 ratings)
Correct Answer
Federico Ziliotto Thu, 12/30/2010 - 12:55
  • Cisco Employee,
Hope this helps,
Fede
kirankumarhm Fri, 12/31/2010 - 08:42
Thanks for sharing the screenshot.
This is for the WLC and ACS via TACACS+ configuration right ?
if you have screenshot forRADIUS based configuration for users kindly share the same,
we are implementing 802.1x for users, we are planning for SSID based restrictions, if you have any screenshot for the same please share.
Cheers,
Correct Answer
Federico Ziliotto Fri, 12/31/2010 - 08:52
  • Cisco Employee,
Fede
Related Content
