Outgoing caller id
Jan 7th, 2011
The customer has two companies and they want to be able to select manually which caller id goes out when they make a call. How would they go about doing this?
           Terry
Steven DiStefano Fri, 01/07/2011 - 10:56
  • Blue, 1500 points or more
Default CLID can be left on the one that is correct.
For the other phone, go to COnfigure> Telephony> Dial Plan> Outgoing to the CLID Tab and set the DID you assigned to that extension as its caller ID.
Steve
terryszpak Fri, 01/07/2011 - 10:58
They want to be able to select which outgoing caller id shows when calling out on a call by call basis on the same set.
Steven DiStefano Fri, 01/07/2011 - 11:11
Do they mind having the multiple extensions (with DIDs) shared on the phone buttons of each phone.
Then they just have to originate from that button, and this should still work I am thinking.
Darren DeCroock Fri, 01/07/2011 - 11:35
  • Silver, 250 points or more
Another option would be to use a different steering digit.
Example:
Dial 9 then the number for Caller ID of Company A
Dial 8 then the number for Caller ID of Company B
You can add the new dial-peers in CCA, but you may not be able to changed the caller-id translation in CCA for the new dial-peers.  I would have to look into that.
terryszpak Fri, 01/07/2011 - 11:53
Darren,
If it works, let me know. It is a small company and they answers calls for two different companies. This might be the best solution.
Darren DeCroock Fri, 01/07/2011 - 13:53
Tested this is CCA 3.0:
You can not change the translation from within CCA, it would have to be done using CLI if you are using a different steering digit.
I guess I would suggest using Steve's option of using another button on the phone, then everything could be done from within CCA.
Darren
terryszpak Fri, 01/07/2011 - 13:56
Darren,
Thanks for the help. I will use Stevens solution.
Terry
terryszpak Fri, 01/07/2011 - 11:51
Steven,
Multiple extensions would be the best way to do it. They wouldn't mind that at all.
