01-09-2011 08:22 AM - edited 03-04-2019 11:00 AM
Am looking at purchasing a router that is capable of serving a WAN bearer at up to 1Gbps. The 3945E has had good reviews as a high throughput router but the datasheets suggests performance of 350Mbps. It also states that additional performance can be ensured by adding SPE modules. Does anyone know whether the 3945E could achieve up to 1Gbps with SPE modules?
If the 3945E can't achieve such performance, I would appreciate alternative model suggestions. The key features I am after are:
IPV4 and IPV6 support
L2tpV3 support
BGP
IP SLA
1Gb Copper Connections on-board with capability of at least 4 Ports
Mike
01-09-2011 11:28 AM
07-30-2014 05:17 AM
It would be safer to have the ASR1000 (ASR1001) which offers 2.5Gbps and scalable to 5gbps
01-09-2011 01:09 PM
The ASR range is your best bet. It will do >1Gbs per interface as compared to the 3945E.07-30-2014 07:25 AM
Have you looked at the new 4451-X ISR?
Supposedly the same pricing as the 3945E, but with 1-2gpbs+ performance.
Also with very low impact when turning on features in comparision with the older ISR routers.
I saw a presentation about it on Cisco Live Virtual.
Edit: Sigh.. replying to a necro thread. :(
02-06-2023 11:56 AM
I know. Sometimes you just get so excited to be able to contribute that you don't look at the date posted.
