01-10-2011 06:59 PM - edited 03-01-2019 09:47 AM
NetApp's Interoperability Matrix Tool (IMT) does not show direct attach support yet with UCS 1.4(1i) for FC or FCoE.
Presumably it will be supported. Any idea how long that'll take?
-Craig
01-11-2011 10:11 AM
Craig
Yes, it is in progress and and *expected* on IMT end of Jan/early Feb 2011.
--Manish
01-11-2011 10:53 AM
I assume something similar is true for the EMC Interoperability matrix (http://www.emc.com/products/interoperability) ?
01-11-2011 11:34 AM
Yes- though EMC is expected mid-Feb/March.
--Manish
02-17-2011 09:59 PM
I may be wrong, but as far as I could see there's no specific FC support for any B-Series on the published Netapp matrix... although is safe to assume that since there are many CVDs and Cisco/Netapp offer FlexPods, the infrastructure is supported with MDS.
Also there's no iSCSI support with the C Series (again, it's safe to assume that this works, right?)
Any advice/other place to verify Cisco/Netapp support?
Thanks and regards,
Sebastian.
02-28-2011 02:16 AM
It is supported now, with a caveat about zoning though:
http://now.netapp.com/NOW/knowledge/docs/adapters/CiscoUCS.pdf
"NetApp supports attaching FC and FCoE targets to the Cisco UCS 6100 Fabric Interconnect, but, at this time, strongly recommends that you use single initiator zoning with this configuration. [...] Because the Cisco UCS does not currently allow you to create and/or modify zoning data directly on a UCS 6100 Fabric Interconnect, you must use an upstream MDS or Nexus switch to configure zoning."
Radek
07-07-2011 07:08 AM
Can this netapp document be posted? It needs a login in order to see it.
Thanks!
