Nexus 7000 copy run start "config change is already in progress"
Answered Question
Jan 14th, 2011
we have an N7k with redundant supervisors.
After a copy run start command was aborted (ctrl-c) because it took to mutch time, we can no longer save te configuration.
n7k# copy run startup-config
Configuration update aborted: another request for config change is already in progress
n7k# sh startup-config
configuration change in progress
We tried reloading the standby supervisor, but it won't boot anymore.
The switch is only live for 4 weeks and i hate to have to powercycle it already.
Does anyone have an idea how to recover from this?
Jacco
Correct Answer by habadr about 6 years 3 months ago
Hi Jacco,
What is the NX-OS version that you are running. I think you are hitting a bug (CSCtj44206).
From the bug toolkit
"N7K-reg : 5.1.1 S37: copy r s aborted due to timeout.
Symptom:
The utaker klm queue overflows. A syslog of this format will be seen in the supervisor's show logging output.
%KERN-2-SYSTEM_MSG: Utaker overflowed. Size -40/5242880 - kernel
Conditions:
One of the conditions when this can happen is when a large number of processes exit/crash.
Workaround(s):
Reloading the relevant supervisor is the workaround. If the issue is seen on the active sup, then perform a switchover. If seen on the standby sup, reload the standby module."
It is fixed in 5.1.2
Hatim Badr
Overall Rating: 3.5 (2 ratings)
Correct Answer
habadr Fri, 01/14/2011 - 06:30
  • Cisco Employee,
Hi Jacco,
Symptom:
Conditions:
Workaround(s):
Hatim Badr
jbraat Sun, 01/16/2011 - 23:22
Thanks Hatim,
this looks like the problem we have. We are running 5.1(1a) and i see a "utaker" message in the logs.
However the sollution in the bug toolkit about reloading the supervisor is a problem. We tried reloading te standby and now it is stuck in powered-up state. So we can't switchover and restart the current active supervisor anymore. I guess we have to restart the chassis.
Again thanks for the input,
Jacco
tschaffran Tue, 01/25/2011 - 11:31
Has any other workaround been identified to kill the hung process?  I am facing the same issue, but I fear my
startup-config may be corrupt and when I power cycle the chassis, it will boot into an unconfigured state.
srinraja Thu, 08/02/2012 - 04:13
Hello All,
I have similar problem where difference of running config are not copied to startup.
Device having OS version with Nexus7000 5.0.3. Am i hitting the same bug got fixed in 5.1.2 version?
Sh run
version 5.0(3)
boot kickstart bootflash:/n7000-s1-kickstart.5.0.3.bin sup-1
boot kickstart bootflash:/n7000-s1-kickstart.5.0.3.bin sup-2
Srini R
Related Content
