USERNAME WITH PRIVILEGE 15
Jan 14th, 2011
Hello Dear's,
I have created a user with command username cisco privilege 15 password cisco when he telnet to the switch he is asked for the enable secret passwrd why??????
Overall Rating: 5 (2 ratings)
lgijssel Fri, 01/14/2011 - 10:08
Hello Estela,
Can you please post a capture of the login dialog?
It would help to see where exactly this situation occurs.
Please also provide the config lines involved and the platform on which you are having this issue.
(pix/asa, router or switch) eventually including version info.
regards,
Leo
estelamathew Fri, 01/14/2011 - 10:28
please find the Attached  configs
login as: cwlms
[email protected]'s password:
SWITCH>en
Password:
lgijssel Fri, 01/14/2011 - 11:10
The attachment is in queued state and cannot be opened.
Still I think you may be missing some aaa config lines.
Can you fix or retry the attachment?
regards
Leo
Nagaraja Thanthry Fri, 01/14/2011 - 10:55
By default the VTY lines have a privilege level of "0". Please try the following:
line vty 0 4
privilege level 15
exit
Now, if you login, you should be able to get directly into the enable mode.
Hope this helps.
NT
estelamathew Fri, 01/14/2011 - 11:02
This will allow everybody in privilege 15???? I don't want everybody to access on level 15 i have certain users on different privilege levels
Dan-Ciprian Cicioiu Fri, 01/14/2011 - 11:07
do you have any "aaa" configuration on the switch ? or just using login local under the line vty?
Can you try to paste here the line configuration , it seams that there is a problem with attached config.
Dan
Nagaraja Thanthry Fri, 01/14/2011 - 11:12
The user privilege takes precedence over the line privilege. So, if the user has a lower privilege level, that should override the line privilege.
Hope this helps.
NT
Dan-Ciprian Cicioiu Fri, 01/14/2011 - 11:18
Yes , but if it has aaa authorization , it is normal to check the enable even if there is any default privilege.
Dan
estelamathew Fri, 01/14/2011 - 11:28
NO user level does'nt take precedence i tried just now, It put user level 2 also in level 15.
There is no AAA,it is local authentication.
line con 0
line vty 0 4
access-class YOU_ME in
exec-timeout 5 0
password 7 08364D5D1D1C1216060E1E25
login local
transport input ssh
line vty 5 15
exec-timeout 5 0
no login
transport input ssh
lgijssel Fri, 01/14/2011 - 11:55
Local authentication is one thing but assigning a privilege level falls under authorization.
Please check this link on aaa, I hope this will enable you to configure a solution.
http://www.cisco.com/en/US/docs/security/asdm/6_2/user/guide/aaasetup.html#wp1284305
It should be something like:
aaa new-model
aaa authentication login default group radius local
aaa authorization exec default group radius local
but then without the radius stuff.
regards,
Leo
Dan-Ciprian Cicioiu Fri, 01/14/2011 - 11:59
Hi Leo ,
Here it is :
Router#sh run | i aaa
no aaa new-model
Router#
Router#
Router#sh run | b line
line con 0
login local
line aux 0
line vty 0 4
end
Router#sh run | i user
username c privilege 15 secret 5 $1$k/W8$yvjhRXM7TQDaRhQGLanSR1
Router#
Router#exi
Router con0 is now available
Press RETURN to get started.
User Access Verification
Username: c
Password:
Router#sh priv
Current privilege level is 15
Router#
Dan
estelamathew Fri, 01/14/2011 - 12:08
Hello Leo,
It can be done without AAA also,
I have 1 switch in my network in which i m accessing directly in privilege (#) mode.
lgijssel Fri, 01/14/2011 - 13:18
It can be done without an AAA-server but you need something similar to the few lines proposed to make it work with local authentication/authorization. This is because you normally login to level1 and then need the additional enable pw to go to level 15. You want to modify the default behavior and this requires additional config.
regards,
Leo
cadet alain Fri, 01/14/2011 - 14:55
Hi Leo,
I already did it like the OP without any problem but on some platforms/ IOS it didn't work so it can be done without AAA
Regards.
Alain.
estelamathew Mon, 01/17/2011 - 10:25
Hello Experts
what can be the issue,i m hitting may be IOS issues if i upgrade it will help me ????
Thanks.
lgijssel Mon, 01/17/2011 - 10:42
Did you try it like this:
sw-test(config)#
sw-test(config)#user emgi privilege 15 password cisco
sw-test(config)#
sw-test(config)#lin vty 0 4
sw-test(config-line)#login ?
  local   Local password checking
  tacacs  Use tacacs server for password checking
sw-test(config-line)#login local
sw-test(config-line)#^Z
Username: emgi
Password:
sw-test#sh priv
sw-test#
System image file is "flash:c2950-i6q4l2-mz.121-22.EA2.bin" (Ancient!)
estelamathew Thu, 01/20/2011 - 11:00
I have a switch model Cisco Catalyst 3550 48 SMI Switch i have uploaded 12.2.44.SE(6) ED the latest uptill date,  The switch model number is 3550 48 SMI and i have uploaded the IOS 12.2.44.SE(6) EMI The software is uploaded successfully with no errors but still i have same issue,Is it the switch is supported with the above software How i will come to know.
The  Feature Navigator shows me the image as in the attached, but the image is too old,Can anybody confirm me the image ihave installed is perfect.
Tomas Fidler Thu, 01/20/2011 - 23:37
Hi Estela,
ok... I don't have this particular device but why not try least painful way. If it doesn't break your security policy why not enable aaa like this:
aaa new-model
aaa authentication login VTYLOGIN local
aaa authorization exec VTYLOGIN local
line vty 0 4
login authentication VTYLOGIN
authorization VTYLOGIN
It will solve your problem, OK it doesn't solve original issue... but it will work and you will not see any diference
Tomas
ebarticel Thu, 01/20/2011 - 18:28
I think you should add "login local" in vty line config mode.
login local it will point to the username you created
Also when you create the username with level 15 you have to user "secret" instead of password, because you know that when you have configured "enable password" and "enable secret" , the enable secret will be used.
Because you have enable secret configured on the switch/router, it will always ask for the "enable secret".
Eugen
estelamathew Thu, 01/20/2011 - 22:05
I have login local enable also after upgrading to latest new IOS the issue is same i have been asked for the enable secret for the privilege 15 user.
ebarticel Fri, 01/21/2011 - 21:10
Hi estela,
Try this commands if you still have the problem:
S(config)#username TELNET priviledge 15 secret cisco
S(config)#line vty 0 15
S(config-line)#login local
S(config-line)#priviledge level 15
S(config-line)#end
Hope this will help
Eugen
