Router is not boot after rommon reset
Jan 14th, 2011
I just power on 2951 Router and erase default configuration and reload after that router show username I write username Cisco password Cisco router show access deny.I did password break from rommon mode write reset command and show up characters that i cannot read. I can do nothing in this stage. It would be very appreciated if anyone helps to solve this problem.
Biplob
Reza Sharifi Fri, 01/14/2011 - 20:02
  • Cisco Designated VIP,
    2017 LAN
Try changing the baud rate to 9600 (default) while you are in Rommon and test again
Reza
aminulnt Fri, 01/14/2011 - 20:20
Hi Reza
Thanks for your reply.I did it but it's not working.Any information would be highly appreciated.
Biplob
Reza Sharifi Fri, 01/14/2011 - 20:34
    2017 LAN
Biplob,
Usually when you see garbage on the screen, it is baud rate issue.  Try a different one like 38400 and 115200 and test.
Reza
aminulnt Sat, 01/15/2011 - 09:23
Hi Reza
Thanks for your mail.I am able to get into the router but showing username.I put username cisco and passeord cisco.Can you tell me what should i do.
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
Here are the Cisco IOS commands.
username   privilege 15 secret 0
no username cisco
Replace and with the username and password you want
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
User Access Verification
Username:
Username:
% Username:  timeout expired!
Username: cisco
Password:
% Login invalid
Username:
biplob
Reza Sharifi Sat, 01/15/2011 - 11:00
    2017 LAN
Ok, login with  username "cisco" and with the password "cisco".
Then go to config mode and create a new user name and password
Example:
username biplob privilege 15 secret 0 password biplob
then
no username cisco
now biplob username is your new one
Reza
aminulnt Fri, 01/21/2011 - 07:04
Hi Reza
Thanks .Sorry to late.cisco username and password was not working. After that I broke password from rommon. Now it's working.
Biplob
