How to monitor bandwidth of vlan on switch
Jan 20th, 2011
Hi all,
I need your help to monitor or to see the bandwidth of vlan on switch, I read that this process is with VLAN access maps but I don’t know how.
Could you give me one example of configuration?
Thanks in advance
sean_evershed Thu, 01/20/2011 - 18:49
How is your network monitoring tool configured? Do you want to a span port to direct traffic to this device for analysis?
If so see below an example config for a 6500
http://www.cisco.com/en/US/products/hw/switches/ps708/products_white_paper09186a008017b753.shtml
A simpler alternative is to use SNMP polling to monitor bandwidth consumption on a VLAN interface.
Please remember to rate posts that are helpful.
jprodrig01 Thu, 01/20/2011 - 20:35
Mi network topology is attached , I don`t have vlan port only two trunks ports, about 30 vlans in this moment, and I need the input rate and output rate of each vlan on the trunks.
thanks for your help
sean_evershed Fri, 01/21/2011 - 01:13
Do the VLANs only exist on the VMWare Server?
Assuming your 4500 switch has the capability I would suggest configuring Netflow.
This will allow you to graph bandwidth utilization for source and destination IP addresses.
jprodrig01 Fri, 01/21/2011 - 07:57
yes the VLANs only exist on the VMWare Server, Im going to try to configure netflow  I don´t know if switch has the capability.
Related Content
