blue indicator light on 1131
lcaruso
Level 6
Level 6
The ringed indicator light on the 1131 normally glows green. What is indicated when it is glowing blue instead? Is this a power issue?
3 Accepted Solutions
Madhuri C
Please take a look at the below table:
Table 3-1     LED Signals
Message type
Cable Bay Area
Top of Unit
Meaning
Ethernet LED
Radio LED
Status LED
Operating status
Green
Ethernet link is operational.
Blinking green
Transmitting or receiving Ethernet packets.
Blinking green
Transmitting or receiving radio packets.
Blinking
dark blue
Software upgrade in progress
Association status
Light green
Normal operating condition, but no wireless client devices are associated with the unit.
Blue
Normal operating condition, at least one wireless client device is associated with the unit.
Cisco IOS errors
Blinking amber
Transmit or receive Ethernet errors.
Blinking amber
Maximum retries or buffer full occurred on the radio.
Red
Red
Amber
Software failure; try disconnecting and reconnecting unit power.
Amber
General warning, insufficient inline power (see the "Low Power Condition for Autonomous Access Points" section).
Boot loader status
Green
Green
Green
DRAM memory test ok.
Off
Blinking green
Blue-green
Initialize Flash file system.
Off
Green
Pink
Flash memory test ok.
Green
Off
Dark blue
Ethernet test ok.
Green
Green
Green
Starting Cisco IOS.
Boot loader warnings
Off
Off
Yellow
Ethernet link not operational.
Red
Off
Yellow
Ethernet failure.
Amber
Off
Yellow
Configuration recovery in progress
(Mode button pressed for 2 to 3 seconds).
Off
Red
Pink
Image recovery
(Mode button pressed for 20 to 30 seconds).
Blinking green
Blinking red
Blinking pink
Image recovery in progress and Mode button is released.
Boot loader errors
Red
Red
Red
DRAM memory test failure.
Off
Red
Blinking red and blue
Flash file system failure.
Off
Amber
Blinking red and blue-green
Environment variable (ENVAR) failure.
Amber
Off
Blinking red and yellow
Bad MAC address.
Red
Off
Blinking red and off
Ethernet failure during image recovery.
Amber
Amber
Boot environment error.
Red
Amber
No Cisco IOS image file.
Amber
Amber
Boot failure.
Link :  http://www.cisco.com/en/US/docs/wireless/access_point/1130/installation/guide/113h_c3.html#wpxref37237
Madhuri
Madhuri C
LIGHT GREEN = Access Point is operational, but no wireless clients are attached
BLUE = Access point is opertional and atleast 1 wireless is associated to the AP
ORANGE = Power issue at the access point
RED = Firmware issue
22 Replies 22
Madhuri C
Message type
Cable Bay Area
Top of Unit
Meaning
Ethernet LED
Radio LED
Status LED
Operating status
Green
Blinking green
Blinking green
Blinking
dark blue
Association status
Light green
Blue
Cisco IOS errors
Blinking amber
Blinking amber
Red
Red
Amber
Amber
Boot loader status
Green
Green
Green
Off
Blinking green
Blue-green
Off
Green
Pink
Green
Off
Dark blue
Ethernet test ok.
Green
Green
Green
Starting Cisco IOS.
Off
Off
Yellow
Red
Off
Yellow
Ethernet failure.
Amber
Off
Yellow
Off
Red
Pink
Image recovery
Blinking green
Blinking red
Blinking pink
Boot loader errors
Red
Red
Red
Off
Red
Off
Amber
Amber
Off
Bad MAC address.
Red
Off
Amber
Amber
Red
Amber
Amber
Amber
Boot failure.
Madhuri
Madhuri C
thank you.
mgallmann
I have an combination of lights that are not named in the Cisco 1131G-A-K9 manuals,  The Status LED is a constant pink.  The ethernet is blinking green with standard activity.  I've been unable to get the SSID to broadcast despite trying different software versions (currently c1130-k9w7-tar.123-4.JA2) and double-checking my configurations.  I've checked the flash file system.  The image's were updated using HTTP.  I've scoured the internet to no avail.  Any help would be appreciated.  Thanks.
Console into the AP and reboot the AP and post the output.  That will have the reason why its like that.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Scott Fella
This is autonomous, so do you have it in a 802.af PoE switch
-Scott
Scott Fella
If its a power issue, take a look at this doc
http://www.cisco.com/en/US/docs/wireless/access_point/1130/installation/guide/113h_c3.html#wp1057645
-Scott
No it's being powered by the 48V adapter.  The ethernet runs to a Cisco 4507 which I believe does not support POE.
You have ssid's configured for the AP?  can you post your show run-config?
Scott
-Scott
Alright.  So at first I just configured the SSID.  Now when I exit out of the web browser and open up a telnet session there are configurations that I never even made ( the ip RADIUS source, and the SNMP).  I've been careful not to have two management connections open while making changes.
ap>en
Password:
ap#sh run
ap#sh running-config
Building configuration...
Current configuration : 1933 bytes
version 12.3
no service pad
service password-encryption
hostname ap
enable secret 5 $1$Iqff$NwLuIeARC7kTVaXtlHVIB0
username Cisco password 7 1531021F0725
ip subnet-zero
ip domain name westernind.com
ip name-server 192.168.34.32
no aaa new-model
dot11 ssid WTGarlandAP
   authentication open
power inline negotiation prestandard source
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit 7 F2F80C353D3AD67412F9CD485817 transmit-key
encryption mode wep mandatory
ssid WTGarlandAP
short-slot-time
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
rts threshold 500
rts retries 50
packet retries 50
station-role root
beacon period 50
beacon dtim-period 50
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 192.168.34.82 255.255.255.0
no ip route-cache
ip default-gateway 192.168.34.31
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging snmp-trap emergencies
logging snmp-trap alerts
logging snmp-trap critical
logging snmp-trap errors
logging snmp-trap warnings
control-plane
bridge 1 route ip
line con 0
transport preferred all
transport output all
line vty 0 4
login local
transport input all
line vty 5 15
login
transport input all
end
ap#
And when I went into NETWORK INTERFACES > RADIO0-802.11g > SETTINGS (tab) before I could apply the "ENABLE" button it was asking me to put in the RTS Threshold and the DTIM, which I've never had it do.  But perhaps it was because Im using an earlier version than before.  Random question:  Do the system software and bootloader versions have to be the same?
I usually use the command line for the confiugration, so really have no clue what the gui will ask.  As far as the bootloader, as long as its not too far off, then that is fine.  I have never had to upgrade the bootloader, but thats just me:)
Can you post your show ip int brief
Scott
-Scott
Interface                  IP-Address      OK? Method Status                Protocol
BVI1                       192.168.34.82   YES NVRAM  up                    up
Dot11Radio0                unassigned      YES NVRAM  up                    up
FastEthernet0              unassigned      YES NVRAM  up                    up
