Mobile 8 / IPhone roaming Issue
The Apple IPhone running Cisco Mobile 8/8.1 has roaming issue:
We are using a 5508 (WiSM) running 6.0.199.4 code. The AP's in the area are the 1142 and the 1232. the SSiD has QOS set to voice/Platinum. Cisco (and ASCOM) phones are working and roam just fine.
However when using the I-Phone (Mobile-8/8.1 app utilizing the Cisco Call Manager) there is a less than 1 second voice drop or dead air when roaming from AP to AP. The call does not drop and you don't hear anything from either end of the call for less than 1 second, the call then resume normally (until the next roam)
I do have a Cisco TAC case open, but they have come back with nothing. Has anyone heard of this issue before?
Thanks!
-rr
Nicolas Darchis Tue, 01/25/2011 - 11:23
  • Cisco Employee,
Maybe you should give more details, like your SSID security configuration. The current analysis of the TAC case (what has been checked already) etc ...
Which SSID is making the roaming break ?
rhodrijenkins Tue, 05/24/2011 - 01:49
We have experienced the same problem with Mobile 8.1. The configuration is as described above and Cisco 7920 series phones also working fine.
I'm using dot1x with PEAP auth, I've tried disabling Cisco Aironet extentions on the SSID but this makes no difference. I also find the same problem but much worse using Blackberry MVS.
Personally, I put this down to the implementation of the wireless card/802.11 in the phone, Unfortunately, I think we'll just have to put up with this until there is more standardisation in the end client devices with regards to QoS etc.
If TAC came back with any advice I'd be interested to hear it.
Rhodri
josemvigueras Wed, 06/15/2011 - 06:23
have you tried another type of authentication?, maybe you can prepare another SSID with WPA2 and PSK and see the differences, dot1x is not the best if you are looking for fast roaming.
b.garczynski Tue, 07/05/2011 - 11:43
I agree that our best bet is to use a PSK for the IPhone and most other mobile devices. In order to use fast roaming with 802.1x the client will need to support CCKM via CCX. While many non Cisco devices do support CCX I am not sure that the IPhone does. The IPhone is also at a disadvantage since it only has a 2.4ghz radio and no 5ghz capability. You may also try to reduce the total number of SSIDs to reduce the number of beacons the IPhone needs to listen to.
K D Sun, 09/11/2011 - 22:18
Hi RR,
Did Cisco come back with any solutions for this? Or what workaround did you do, to fix this?
rhodrijenkins Mon, 09/19/2011 - 01:30
Unfortunately not. The users have now just gotten used to it
Rh
Nicolas Darchis Thu, 09/22/2011 - 12:10
  • Cisco Employee,
Out of experience, it seems that the iphone does not support fast roaming .It for sure does not do CCKM but it also seems that it doesn't do wpa2 fast roaming ... So the problem is on the iphone side.
George Stefanick Thu, 09/22/2011 - 12:13
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
I did extensive captures and the iPhone creates a new PMK-ID for each ap. And it doesnt even do "fast roam back", either.
