tftpdnld
Answered Question
Jan 25th, 2011
l did used the tftpdnld to get the IOS up and running still encountering problems. Could someone help me out pls.
rommon 16 > IP_ADDRESS=192.168.1.3
rommon 17 > IP_SUBNET_MASK=255.255.255.0
rommon 18 > DEFAULT_GATEWAY=192.168.1.1
rommon 19 > TFTP_SERVER=192.168.1.2
rommon 20 > TFTP_FILE=c2600-adventerprisek9-mz.124-9.t2.bin
rommon 21 > tftpdnld
          IP_ADDRESS: 192.168.1.3
      IP_SUBNET_MASK: 255.255.255.0
     DEFAULT_GATEWAY: 192.168.1.1
         TFTP_SERVER: 192.168.1.2
           TFTP_FILE: c2600-adventerprisek9-mz.124-9.t2.bin
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash will be lost!
Do you wish to continue? y/n:  [n]:  y
PHY did not complete auto-negotation, status = 0x100
ARP: address resolution for 192.168.1.2 timed out.
ARP failed with failure code 1.  TFTP transfer aborted.
TFTP: Operation terminated prematurely.
Correct Answer by Phillip Remaker about 5 years 11 months ago
With the crossover cable, you should be able to successfully run tftpdnld, which is WAY faster and more reliable than xmodem.
The xmodem failure may be because of flow control - Pick a slower xmodem speed or use tftpdnld.
If you can't get a crossover cable, you can connect the laptop and router to a switch.  A direct connection is not needed for tftp.
Overall Rating: 5 (1 ratings)
cadet alain Wed, 01/26/2011 - 03:04
which type of ethernet cable are you using? how is the ftp side port configured( duplex,speed)?On what port of router are you connected( type of interface)
Regards.
Alain.
morenike1_2 Wed, 01/26/2011 - 07:46
Hi Alain
Am using a straight through RJ54 cable to connect the laptop to the interface fa0/0 on router before these errors started. That was how l was transferring the IOS to the flash which was working fine.Because l have set up a VOIP lab at home which l transferred the firm ware into the flash for the ip phones to be able to communicate to the CME which is the router 2620XM. I have the console cable which is connected to the console port for my configuration. But since these errors has started, there is no chance for me to connect the laptop to the router because the info will not come up. I could only connect to the router 2620XM through console cable on the console port for the configuration of the router.All it does is to go into the rommon mode when it's been powered up. So to answer the questions you asked, l used a straight through cable to connect to the router on the interface fa0/0. I did think l change the speed to 100 and duplex to full but am not too sure at the moment, l don't want to mislead you.
Leo Laohoo Wed, 01/26/2011 - 13:24
2600 router FE interface are do not support MDI/MDI-X.  So you should use cross-over cable.
morenike1_2 Thu, 01/27/2011 - 08:20
l have connected the laptop with the cross-over cable and this the result that l got. Ready to receive file c2600-adventerprisek9-mz.124-9.t2.bin ... that was where it got stock and no file was transferred after this point. I waited for 30mins and nothing happened. Any solution please.
rommon 1 > confreg
           Configuration Summary
   (Virtual Configuration Register: 0x3921)
enabled are:
load rom after netboot fails
console baud: 115200
boot: the boot helper image
do you wish to change the configuration? y/n  [n]:  y
enable  "diagnostic mode"? y/n  [n]:  n
enable  "use net in IP bcast address"? y/n  [n]:  n
disable "load rom after netboot fails"? y/n  [n]:  n
enable  "use all zero broadcast"? y/n  [n]:  n
enable  "break/abort has effect"? y/n  [n]:  n
enable  "ignore system config info"? y/n  [n]:  n
change console baud rate? y/n  [n]:  y
enter rate: 0 = 9600,  1 = 4800,  2 = 1200,  3 = 2400
4 = 19200, 5 = 38400, 6 = 57600, 7 = 115200  [7]:  7
change the boot characteristics? y/n  [n]:  n
enabled are:
do you wish to change the configuration? y/n  [n]:  n
rommon 2 > reset
System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
Copyright (c) 2002 by cisco Systems, Inc.
C2600 platform with 65536 Kbytes of main memory
loadprog: bad file magic number:      0x0
boot: cannot load "flash:"
rommon 1 > xmodem c2600-adventerprisek9-mz.124-9.t2.bin
Do not start the sending program yet...
         File size           Checksum   File name
     18836 bytes (0x4994)     0xd99d    bacdprompts/app-b-acd-2.1.2.2-ReadMe.txt
     24985 bytes (0x6199)     0xc81e    bacdprompts/app-b-acd-2.1.2.2.tcl
     35485 bytes (0x8a9d)     0x41de    bacdprompts/app-b-acd-aa-2.1.2.2.tcl
     75650 bytes (0x12782)    0x1ff9    bacdprompts/en_bacd_allagentsbusy.au
     83291 bytes (0x1455b)    0xf5f8    bacdprompts/en_bacd_disconnect.au
     63055 bytes (0xf64f)     0x9f34    bacdprompts/en_bacd_enter_dest.au
     37952 bytes (0x9440)     0xd8a9    bacdprompts/en_bacd_invalidoption.au
    496521 bytes (0x79389)    0x206e    bacdprompts/en_bacd_music_on_hold.au
    123446 bytes (0x1e236)    0x1dab    bacdprompts/en_bacd_options_menu.au
     42978 bytes (0xa7e2)     0x5be6    bacdprompts/en_bacd_welcome.au
     34794 bytes (0x87ea)     0x5b97    bacdprompts/en_bacd_xferto_operator.au
     22542 bytes (0x580e)     0xb849    CME-7-0-full-readme-v.1.0.txt
    131470 bytes (0x2018e)    0x8e9a    Desktops/320x212x12/CampusNight.png
     80565 bytes (0x13ab5)    0x80f3    Desktops/320x212x12/CiscoFountain.png
       628 bytes (0x274)      0x3106    Desktops/320x212x12/List.xml
    109076 bytes (0x1aa14)    0x6464    Desktops/320x212x12/MorroRock.png
    108087 bytes (0x1a637)    0x3746    Desktops/320x212x12/NantucketFlowers.png
     10820 bytes (0x2a44)     0xff97    Desktops/320x212x12/TN-CampusNight.png
      9657 bytes (0x25b9)     0xd446    Desktops/320x212x12/TN-CiscoFountain.png
      7953 bytes (0x1f11)     0x8fe2    Desktops/320x212x12/TN-Fountain.png
      7274 bytes (0x1c6a)     0xa10d    Desktops/320x212x12/TN-MorroRock.png
      9933 bytes (0x26cd)     0x676e    Desktops/320x212x12/TN-NantucketFlowers.
png
    138278 bytes (0x21c26)    0x9344    Desktops/320x212x12/Fountain.png
      3987 bytes (0xf93)      0xc9dd    gui/admin_user.html
    650596 bytes (0x9ed64)    0x5cd9    gui/admin_user.js
      1029 bytes (0x405)      0xff88    gui/CiscoLogo.gif
       617 bytes (0x269)      0xc8f3    gui/CME_GUI_README.TXT
       953 bytes (0x3b9)      0xa910    gui/Delete.gif
     16344 bytes (0x3fd8)     0xab45    gui/dom.js
       864 bytes (0x360)      0xa225    gui/downarrow.gif
      6146 bytes (0x1802)     0xaa95    gui/ephone_admin.html
      4558 bytes (0x11ce)     0x08fd    gui/logohome.gif
      3866 bytes (0xf1a)      0xe296    gui/normal_user.html
     78428 bytes (0x1325c)    0x3dd1    gui/normal_user.js
      1347 bytes (0x543)      0x5ef3    gui/Plus.gif
       843 bytes (0x34b)      0x36ad    gui/sxiconad.gif
       174 bytes (0xae)       0xbc76    gui/Tab.gif
      2431 bytes (0x97f)      0xfa1a    gui/telephony_service.html
       870 bytes (0x366)      0x52b9    gui/uparrow.gif
      9968 bytes (0x26f0)     0x4469    gui/xml-test.html
      3412 bytes (0xd54)      0x1f90    gui/xml.template
    496521 bytes (0x79389)    0x206e    music-on-hold.au
   2496963 bytes (0x2619c3)   0x295a    phone/7945-7965/apps45.8-3-2-27.sbn
    585536 bytes (0x8ef40)    0x2cc5    phone/7945-7965/cnu45.8-3-2-27.sbn
   2453202 bytes (0x256ed2)   0x59b8    phone/7945-7965/cvm45sccp.8-3-2-27.sbn
    326315 bytes (0x4faab)    0x5d4b    phone/7945-7965/dsp45.8-3-2-27.sbn
    555406 bytes (0x8798e)    0xde7b    phone/7945-7965/jar45sccp.8-3-2-27.sbn
       638 bytes (0x27e)      0x587b    phone/7945-7965/SCCP45.8-3-3S.loads
       642 bytes (0x282)      0x6188    phone/7945-7965/term45.default.loads
       642 bytes (0x282)      0x3e37    phone/7945-7965/term65.default.loads
   7821474 bytes (0x7758a2)   0x178a    phone/7937/apps37sccp.1-1-1-1.bin (bad c
hecksum: 0x392c)
getdirent: bad file magic number, possibly out of sync
WARNING: All existing data in bootflash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n  [n]:  y
Correct Answer
Phillip Remaker Thu, 01/27/2011 - 18:16
morenike1_2 Tue, 02/01/2011 - 03:53
This is the best way to restore the IOS into the router which l use. Use RJ45 crossover cable to connect both the router and the laptop that has the tftp server where the IOS is stored and be transferred from to the flash memory on the router . I was able to successfully run tftpdnld, which is the best WAY faster and more reliable than xmodem, this was what l did and it it did work successfully.
rommon 1 > IP_ADDRESS=10.10.71.1
rommon 2 > IP_SUBNET_MASK=255.255.255.0
rommon 3 > DEFAULT_GATEWAY=10.10.71.1
rommon 4 > TFTP_SERVER=10.10.71.2
rommon 5 > TFTP_FILE=10.10.71.2
rommon 6 > TFTP_FILE=c2600-adventerprisek9-mz.124-9.t2.bin
rommon 7 > tftpdnld
IP_ADDRESS: 10.10.71.1
DEFAULT_GATEWAY: 10.10.71.1
TFTP_SERVER: 10.10.71.2
TFTP_FILE: c2600-is-mz.123-17a.bin
Receiving c2600-is-mz.123-17a.bin from 10.10.71.2!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
File reception completed.
Copying file c2600-is-mz.123-17a.bin to flash.
Erasing flash at 0x61fc0000
program flash location 0x610f0000
rommon 7 > i
program load complete, entry point: 0x80008000, size: 0x10f5270
Self decompressing the image : ########################################## [OK]
Press RETURN to get started!
Router>
Router>en
Router#sh ver
IOS (tm) C2600 Software (C2600-IS-M), Version 12.3(17a), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Mon 12-Dec-05 14:12 by evmiller
Image text-base: 0x80008098, data-base: 0x81A45AD0
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-IS-M), Version 12.3(17a), RELEASE SOFTWARE (fc2)
System image file is "flash:c2600-is-mz.123-17a.bin"
cisco 2620XM (MPC860P) processor (revision 0x100) with 61440K/4096K bytes of memory.
Processor board ID JAD07030DAG (1015747174)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Configuration register is 0x3921
morenike1_2 Tue, 02/01/2011 - 04:03
This is the best way to restore the IOS into the router which l use. Use RJ45 crossover cable to connect both the router and the laptop that has the tftp server where the IOS is stored and be transferred from to the flash memory on the router . I was able to successfully run tftpdnld, which is the best WAY faster and more reliable than xmodem, this was what l did and it it did work successfully. There was an error in the first postage, this is the correct other of what has been entered for the rommom ? > entries.
rommon 5> TFTP_FILE=c2600-adventerprisek9-mz.124-9.t2.bin
rommon 6 > tftpdnld
rommon 7 > i
davinder2010 Sat, 05/05/2012 - 11:53
I know this post is old but I've just had a similar problem.
1. Connect to the 1st port of the router, as in the 1st ethernet port.
2. Use a crossover cable
3. set speed and duplex at both ends (eg on computer / laptop - 100/Full an router in rommon use FE_SPEED_MODE=3)
4. I'm assuming that you have already set the other variables
5. type the command to download the ios image....away you go...
If all else fails, then use the switch.
Well thats how ive just done it on a 2611XM.
