Cisco 4402 LAP1131 Interference Profile Failed for Base Radio MAC:
Jan 26th, 2011
Dropped connections every day, few times a day.
WLC Was working perfectly fine for about a year then had some dropped connections.
Upgraded to the latest firmaware and also default it to the factory and reconfigured it.
Same problem!
Cisco 4402
Software Version 7.0.98.0
8x Cisco: AIR-LAP1131AG-A-K9 also v/7.0.98.0
Overall Rating: 4 (2 ratings)
Surendra BG Wed, 01/26/2011 - 09:05
In general the Interference Profile message occurs when the noise or interference in the area of an AP has risen over the threshold value.
This value can be configured in Wireless > 802.11a/n | 802.11b/g/n > RRM > General
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
peter.kryszyn Wed, 01/26/2011 - 10:24
Yes,
I have seen the setting for noise. its set to -70 by default. What would be more appropriate setting?
wireless wlc Wed, 01/26/2011 - 11:55
Dropped AP-WLC connections ? or dropped client connections ? If its latter, interference might be an issue. Did you introduce any new wireless devices into the network operating in 802.11 frequencies ? (like wireless meeting room systems etc..)
regards
Joe
peter.kryszyn Wed, 01/26/2011 - 12:01
I have clients that are complaining that they loose network connection, and yes I do have many new laptops and Apple Ipads.
This is what I'm seeing now (WPA MIC Error counter measure activated on Radio with MAC 00:22:55:58:85:b0 and Slot ID 0. Station MAC Address is 60:33:4b:46:f0:06 and WLAN ID is 1)
Nam Nguyen Thanh Thu, 03/06/2014 - 02:07
I have the same problem with WLC5508 "
"Interference Profile failed".
Any update for help!.
Thanks.
Scott Fella Thu, 03/06/2014 - 04:55
This is a threshold parameter: "Interference Profile failed" along with some others.  All this does is send alerts to the WLC log, to your syslog or to your WCS/NCS or Prime Infrastructure management tool.  You need to adjust these for your environment if you see too many alerts being triggered.  Interference can be a main issue in downtown big citites and you would bump the value up to reduce the number of alerts you see.  Yes interference will cause issues, but this is an alert threshold and will not fix your interference, just tell you that you have interference due to hitting the X value.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Scott Fella Thu, 03/06/2014 - 05:43
Okay...
Scott
MUQ_1899_ Mon, 02/15/2016 - 09:40
Do an alarm will be raised if there are more than 12 clients connected to the radio by default?
Related Content
