how to route specific IP through VPN tunnel
Answered Question
Jan 31st, 2011
I have set up Remote Access VPN using Cisco VPN.
We use split tunneling to tunel internal IP range to VPN tunnel only.
Now I need to route specific IP address from Cisco VPN Client side
to internal network and through it to Internet.
I have added that specific IP address to split tunell ACL
I can check it using Cisco VPN Client, Status > Statistics, Route Details,
but when I traceroute to that specific IP address it ends on
first hop, ASA public interface.
ASA has 0.0.0.0/0 route set.
What more do I need to set up?
Correct Answer by Federico Coto F... about 6 years 4 months ago
If you need to allow the VPN client to connect to the ASA and u-turn to the Internet you need:
same-security-traffic permit intra-interface
Also, make sure you NAT the traffic:
nat (outside) 1 VPN-range
global (outside) 1 interface
Be careful with the NAT commands above (is just an example and depends on your configuration).
Federico.
Overall Rating: 5 (1 ratings)
Correct Answer
Federico Coto F... Mon, 01/31/2011 - 10:45
  • Green, 3000 points or more
Federico.
rga-rga-rga Mon, 01/31/2011 - 23:35
I already had
in my configuration but NAT was the issue. I had
nat-control
nat (inside) 0 access-list acl_no_nat_inside
nat (inside) 1 0.0.0.0 0.0.0.0
but
nat (outside) 1 172.27.127.0 255.255.255.0
(VPN address range) was missing.
Thanks for the clue!
