VPN Sev=Warning/3 CM/0xA3100027
Jan 31st, 2011
Greetings All,
    When I try to use VPN through a Verizon aircard ,  I loose my connection to the internet.   My company uses Cisco Systems VPN Client Version 4.7.00.0533, Running on: 5.1.2600 Service Pack 3.
The log gives me this message:
1      17:58:09.899  01/12/11  Sev=Warning/3 CM/0xA3100027
Adapter address changed from 75.213.104.118.  Current address(es): 192.168.9.25.
2      17:58:09.899  01/12/11  Sev=Warning/3 IKE/0xE3000068
Failed to send 68 bytes to 69.147.187.2, error = 0xFFFFFFF0
Does anyone have a solution to this problem?  Any help is greatly appreciated.
I live remotely and the Verizon aircard is my only high-speed option.
thanks
Alan
Jennifer Halim Mon, 01/31/2011 - 08:30
  • Cisco Employee,
There is known issue with Verizon aircard and Cisco VPN Client compatibility. From past experience, if you update the driver for your Verizon aircard as well as upgrade the Cisco VPN Client to the latest version, the issue will be resolved.
datafarm1 Mon, 01/31/2011 - 09:16
I have just updated the verizon drivers for the usb760 modem to the latest version.   Can you send me the link to the Cisco VPN Client update that I need for this?
thanks
Alan
Jennifer Halim Tue, 02/01/2011 - 04:47
  • Cisco Employee,
Please kindly get in touch with your company's administrator who should have access to download the latest VPN Client software from cisco.com download site. I am not sure if you have accessed to download the software if you are having guest user access to cisco.com.
datafarm1 Tue, 02/01/2011 - 05:47
Will there be a problem if my version of the Cisco VPN client is different from everyone else at the company?   My company's IT department is very conservative.   The last time I asked them for assistance with this problem their response was 'Get on a wire'.
thanks
Jennifer Halim Tue, 02/01/2011 - 08:46
  • Cisco Employee,
No, there is no issue with running different version of IPSec VPN Clients, unless your IT department has configured policy to only allow that particular version to connect to the VPN headend.
Unfortunately, only your IT department who has accessed to the cisco.com software download site can download the latest version of IPSec VPN Client on behalf of you. I have seen the issue was resolved when running IPSec VPN Client version 4.9. However, please feel free to request for the latest version 5.0 from your IT deparment if it's possible.
The reason why the IT department is a little conservative is probably because it could be harder to manage multiple different version of vpn client, hence they only allow 1 version that they have tested and worked for most scenarios.
datafarm1 Thu, 02/03/2011 - 14:22
OK.  Got the IT department to update my Cisco VPN to the latest version.  Now I'm getting slightly different errors.  Any help is most appreciated.  Here's a sample from the log:
Cisco Systems VPN Client Version 5.0.06.0160
Copyright (C) 1998-2009 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Config file directory: C:\Program Files\Cisco Systems\VPN Client\
1      13:17:09.853  02/03/11  Sev=Warning/2 IKE/0xA3000067
Received an IPC message during invalid state (IKE_MAIN:512)
2      13:18:16.916  02/03/11  Sev=Warning/3 CLI/0xA3900004
Unable to purge old log files. Function returned -4.
3      13:21:07.666  02/03/11  Sev=Warning/3 CM/0xA3100027
Adapter address 75.213.240.219 has changed or not detected.  Current address(es): 192.168.9.96.
4      13:21:07.666  02/03/11  Sev=Warning/3 IKE/0xE3000069
5      13:21:07.666  02/03/11  Sev=Warning/3 IKE/0xE3000069
Failed to send 76 bytes to 69.147.187.2, error = 0xFFFFFFF0
6      13:21:22.681  02/03/11  Sev=Warning/2 CVPND/0xA340000E
Failed to get adapter index.
7      13:21:23.900  02/03/11  Sev=Warning/3 CLI/0xA3900004
8      13:21:24.056  02/03/11  Sev=Warning/3 CLI/0xA3900004
thanks
alan
Jennifer Halim Fri, 02/04/2011 - 09:22
  • Cisco Employee,
Can you please add or modify the following settings in your vpn client profile:
ForceNatT=1
The VPN Client profile is in .pcf extension file and is located in "C:\Program Files\Cisco Systems\VPN Client\Profiles" directory.
If that doesn't work, you can also follow the Novell Client troubleshooting guide:
http://www.novell.com/support/search.do?cmd=displayKC&docType=kc&externalId=3861100&sliceId=1&docTypeID=DT_TID_1_1&dialogID=6992281&stateId=0%200%206984740
Issue seems to be with the aircard compatibility with other softwares within the laptop.
datafarm1 Mon, 02/14/2011 - 07:02
That did the trick!  I've been working successfully through the Verizon aircard for the last week with no problems!
thanks for your support!
-Alan
Jennifer Halim Mon, 02/14/2011 - 14:06
  • Cisco Employee,
Great to hear, Alan. Please kindly mark the post as answered so others can learn the same from your post. Thank you.
datafarm1 Tue, 02/15/2011 - 06:08
Just one more question:  will this fix now work with
all verizon devices, such as a tethered smart phone, or is it specific to the usb760 modem?
Jennifer Halim Tue, 02/15/2011 - 21:09
  • Cisco Employee,
I assume it will for those that doesn't support the NAT-T function on the card itself.
Related Content
