vpn site to site problem
Jan 31st, 2011
From Last week the vpn that was working for months, suddenly it doesn't  longer work.
Nobody has changed the rules or the pre-shared key.
On both sites we have done:
1) reload firewalls
2) we have newly written the pre-shared key
3) more times we have done clear crypto isakmp sa
4) We have removed the vpn configuration and we have newly put the vpn configuration.
the error is:
sh crypto isakmp sa
   Active SA: 2
    Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 2
1   IKE Peer: x.x.x.x /// ip hidden
    Type    : L2L             Role    : responder
    Rekey   : no              State   : MM_WAIT_MSG5
2   IKE Peer: x.x.x.x
ASA# sh crypto isakmp
   Active SA: 1
Total IKE SA: 1
1   IKE Peer: x.x.x.x
The firewalls have different system image
One has 8.3 ASA 5520 and the other has 8.2 ASA 5510
Can anyone help me ?
Best Regards
Carmine
manish arora Mon, 01/31/2011 - 09:52
  • Silver, 250 points or more
The error that you are seeing is generally due to following reasons :-
1> Incorrect peer configuration.
2> iskamp proposal mismatch.
Please post the vpn revalent configuration from both peers for further troubleshooting.
Manish
Carmine De Rienzo Mon, 01/31/2011 - 10:46
firewall a
object-group network DM_INLINE_NETWORK_1
network-object yyy.xx.7.0 255.255.255.0
network-object yyy.xx.8.0 255.255.255.0
network-object yyy.xx.9.0 255.255.255.0
access-list 110 extended permit ip object-group DM_INLINE_NETWORK_1 host 192.zzz.x.10
crypto ipsec transform-set pippo esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map galileo 10 match address 110
crypto map galileo 10 set peer ss.zz.yy.xx
crypto map galileo 10 set transform-set pippo
crypto map galileo interface OUTSIDE
crypto isakmp enable OUTSIDE
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group ss.zz.yy.xx type ipsec-l2l
tunnel-group ss.zz.yy.xx ipsec-attributes
pre-shared-key pippo
Firewall b
object network ff
host 192.zzz.x.10
object-group network DM_INLINE_NETWORK_2
access-list outside_1_cryptomap extended permit ip object ff object-group DM_INLINE_NETWORK_2
nat (INSIDE,any) source static obj-192.zzz.x.0 obj-192.zzzz.x.0 destination static obj-yyy.xx.9.0 obj-yyy.xx.9.0 unidirectional
nat (INSIDE,any) source static obj-yyy.xx.9.0 obj-yyy.xx.9.0 destination static obj-192.zzz.x.0 obj-192.zzz.x.0 unidirectional
crypto map galileo 10 set peer yy.zz.ss.xx
  encryption 3des
  hash sha
  group 2
  lifetime 86400
tunnel-group yy.zz.ss.xx type ipsec-l2l
tunnel-group yy.zz.ss.xx ipsec-attributes
The outside interface on the firewall b has private address and then this private address have to be nat with ip pubblic address.
Best regards
Carmine
manish arora Mon, 01/31/2011 - 11:11
The outside address of firewall B which you said is being Natted , is the NAT happening on another device between the two firewalls ?
Manish
m.kafka Mon, 01/31/2011 - 13:58
  • Bronze, 100 points or more
the recommended configuration of an IPsec endpoint behind a nat (static one-to-one nat) is to use isakmp identity hostname
so that the isakmp identity can match the information of the layer 3
funny it worked in the first place...
on b (which is translated) i would configure:
on a i would:
change the tunnel-group to the hostname (instead of ip address)
add a name which resolves hostname to the public (translated) ip of b
then i would run deb crypto isakmp on a and initiate a tunnel-negotiation from b
and vice-verse a deb cry isak on b and initiate from a
watch carefuly, the debug output differs on 8.2 and 8.3
look for something like "landing on group" or "matching tunnel group"
PS your config, it says on b:
but:
