Nexus 7000 - determining the Jumbo MTU size on an interface.
Feb 7th, 2011
I am trying to determin if Jumbo frames are enabled on out Nexus 7000, and I am getting mixed info back from the swtich.
I looks like the system jumbo MTU size is 9216 by default, but the interfaces all say the MTU of the interface is 1500 bytes. According to this article, the interface MTU should read 9216 is the jumbo frames are enabled globally. Is this correct. Is there a way to verify if Jumbo frame support is turned on?
http://www.cisco.com/en/US/products/ps9670/products_configuration_example09186a0080b44116.shtml
Here is our output from sh run all | sec system
n7k1# sh run all | sec system
no system default switchport
system default switchport shutdown
system jumbomtu 9216
cdp format device-id system-name
  system-priority 4094
And the interface output:
n7k1# sh int po40
port-channel40 is up
vPC Status: vPC number: 40
  Hardware: Port-Channel, address: 0024.f71d.9813 (bia 0024.f71d.9813)
  Description: to msndc-intel-asw Access Switches
  MTU 1500 bytes, BW 20000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s
  Input flow-control is off, output flow-control is off
  Switchport monitor is off
  Members in this channel: Eth1/12, Eth2/12
  30 seconds input rate 27816480 bits/sec, 5672 packets/sec
  30 seconds output rate 33896296 bits/sec, 12904 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 82.15 Mbps, 9.90 Kpps; output rate 37.58 Mbps, 17.28 Kpps
  RX
    57135287297 unicast packets  13338525 multicast packets  2206711 broadcast packets
    57150832533 input packets  69901179046421 bytes
    0 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    100563243159 unicast packets  661949296 multicast packets  4071877704 broadcast packets
    105297070159 output packets  27468942487440 bytes
    0 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble
    0 Tx pause
  2 interface resets
Overall Rating: 5 (2 ratings)
Nathan Eger Thu, 03/17/2011 - 09:23
Did you try looking at the physical interface?  I see the output you listed is for the vPortchannel.
alphaomegait Thu, 03/17/2011 - 15:56
After you turn jumbo frames on globally, you then have to set mtu under the interfaces.
There is a clear example of this in the command lookup for NX OS.  Just search for jumbo frames:
switch# config t
switch(config)# system jumbomtu 9216
switch(config)# show running-config
switch(config)# interface p102
switch(config-if)# switchport
switch(config-if)# mtu 9216
William Mejia M... Mon, 04/09/2012 - 08:51
HI !
I Wil do the same configuration tomorrow. The moment that I execute this, It´s going to result in loss of service?
Oleksandr Nesterov Mon, 04/16/2012 - 09:29
Hi Peter
Try to use
"sh queuing interface eth x/y"
since in "show interface eth x/y" correct MTU may not be visible due to cosbetic issue.
HTH,
Alex
eduardo.ramirez Thu, 09/26/2013 - 15:00
Hi Peter you have to enable this on each interface too  ,  I did with no loss of service  !!!!
Related Content
