L2L VPN ASA to Sonicwall, ASA with dynamic IP
Feb 9th, 2011
Hello everybody
I have the following Scenario.
My SIP trunk provider uses a SonicWall Pro 3060, I need to initiate a IPSec VPN tunnel from an ASA 5505 (ASA1) for SIP traffic to a PBX connected on ASA1's inside.
ASA1 should also connect a VPN to ASA2, ASA2 has a fixed IP
I have not been able to figure out how to initiate the tunnel from the ASA1 to the Sonicwall due to the dynamic IP.
Anyone, pls help.
hkl
Federico Coto F... Wed, 02/09/2011 - 06:46
  • Green, 3000 points or more
For the tunnel between the ASA and the Sonicwall (ASA having a dynamic IP), you can configure either a dynamic-to-static L2L tunnel or EzVPN.
The side having the dynamic IP (ASA) should initiate the tunnel.
Federico.
Hans KRISTIAN LARSEN Tue, 02/22/2011 - 04:58
Federico.
Hey Federico
Thanks for your replay, beeing kind of a newbie could you point me in the right direction for the dyn to stat L2L, prefeerably using asdm.
br
hkl
Related Content
