Hi Friends,Kindly help in uploading IOS in cisco c870 router
itsecurity mk
A couple of days before i removed the flash from router becoz its not working fine,all the screen comes in junk format.
so before deleting flash i took backup but when i am trying to restore flash again its showing error.
System Bootstrap, Version 12.3(8r)YI4,
RELEASE SOFTWARE Technical Support: http://www.cisco.com/techsupport Copyright (c) 2006 by cisco Systems, Inc.
C870 series (Board ID: 1-148) platform with 131072 Kbytes of main memory No bootable image file: flash:/ Unable to open boot file System Bootstrap,
Version 12.3(8r)YI4, RELEASE SOFTWARE Technical Support: http://www.cisco.com/techsupport Copyright (c) 2006 by cisco Systems, Inc.
rommon 1 > confreg 0x2101
rommon 2> i
rommon 3 >
System Bootstrap, Version 12.3(8r)YI4, RELEASE SOFTWARE
rommon 1 >
Leo Laohoo
The fastest way is to use "tftpdnld".
How to Download a Software Image to a Cisco 2600 via TFTP Using the tftpdnld ROMMON Command
http://www.cisco.com/en/US/customer/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
Hi leolahoo,
                Thankx for ur kind help,when i am trying to upload via tftp getting error which below config
             router fe0 connects to symtem via cable. I basically pasted this config into rommon and the image loaded
IP_ADDRESS=192.168.1.99
IP_SUBNET_MASK=255.255.255.0
DEFAULT_GATEWAY=192.168.1.1
TFTP_SERVER=192.168.1.100
TFTP_FILE=c870-advipservicesk9-mz.124-24.T1.bin
tftpdnld -r
TFTP error 1 received (File not foundÌT¸°).
TFTP: Operation terminated
please note windows firewall is disabled.
check this also may be i am doing mistake while assinging ip address.
I put symtem ip address(on which tftp sever is running)
ip address=192.168.1.100
subnet mask 255.255.255.0
default gateway = 192.1689.1.1
On router fe0 interface ip address=192.168.1.1
but i dont understand where i have to assign ip address 192.168.1.99 as i shown above this command is needed  according to syntax.
onemore thing is that when i used below command:
xmodem -c c870-advipservicesk9-mz.124-24.T1.bin
ios downloading  completed but  tell me how to save the image to Flash, after xmodem command
when i put the commands
confreg 0x2101
reset
the router comes in rommom mode again.
I dont know which command save image to flash.
I dont have sufficient privilleges to access bekow link http://www.cisco.com/en/US/customer/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
tftpdnld -r
This means that the filename is either not correct, not found or your TFTP server is pointing to the wrong folder.
Sorry for the delay
really busy for finding the solution at last i found it.
I uploaded ios in rommon mode by using console the steps  used are below.
step1:put ios in computer c: drive or any folder.
step2:open hyperterminal with default setting on router type the command as shown below
step3: rommon 29 > xmodem -c c:\c870-advsecurityk9-mz.124.T.bin
message appears
"Do not start the sending program yet...
WARNING: All existing data in bootflash will be lost! Invoke this application only for disaster recovery." Do you wish to continue? y/n  [n]:  y
Ready to receive file c:c870-advsecurityk9-mz.124.T.bin
step4:go to tranfer select send file .
step5: specify the image file name and location and enter xmodem as a protocol .
step6:click on send to start transfer
. Specify the image file name and location and enter xmodem as the protocol.
the messege receved when transfer successfully complete.
"CDownload Complete!
" Copying file c:c870-advsecurityk9-mz.124.T.bin to flash.
Writing flash:/c870-advsecurityk9-mz.124.T.bin
Write operation will take approximately 85 to 256 seconds
check whether ios save in flash by b elow command
step7:rommon 34 > dir flash:
Directory of flash:/ 2    -rwx  13993708
       c870-advsecurityk9-mz.124.T.bin 9484288 bytes available (13998080 bytes used)
step8: rommon 35 > confreg 0x2102
You must reset or power cycle for new config to take effect put i or reset to reload router
step9: rommon 36 > i now router boots from flash without any problem
. I am posting the  solution because others should not suffer like me.
Message was edited by: itsecurity mk
