ASA WebVPN with SSO on Exchange OWA 2010
Answered Question
Feb 18th, 2011
Hi I was using WebVPN (clientless) with SSO on Exchange OWA 2003 and it was working fine with those SSO POST parameters:
URL: /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} https://<mailserver>/exchweb/bin/auth/owaauth.dll
destination https://<mailserver>/exchange/
flags 0
username DOMAIN\ /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} CSCO_WEBVPN_USERNAME
password /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} CSCO_WEBVPN_PASSWORD
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabla normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} SubmitCreds Log+On
forcedownlevel  0
trusted 0
Now, I'm trying to do the same with OWA 2010 and it doesn't work. I always receive an error about user credentials
For Exchange 2010, I use those parameters:
URL: https://<mailserver>/owa/auth.owa
destination https://<mailserver>/owa/
flags 0
username DOMAIN\CSCO_WEBVPN_USERNAME
password CSCO_WEBVPN_PASSWORD
SubmitCreds Log+On
forcedownlevel  0
trusted 0
Does anyone know how to fix?
Has anyone got it working?
Any help?
Correct Answer by alig.norbert about 6 years 3 months ago
In this setup, I had to change it to HTTP (customer related). It works over HTTPS as well.
Get this tool http://www.fiddler2.com/fiddler2/.
URL:      http://internal-mail-server-ip/owa/auth/owaauth.dll
post-parameter:
destination:          http://internal-mail-server-ip/owa/
flags:                    0
forcedownlevel:    0
trusted:                 0
username:            CSCO_WEBVPN_USERNAME
password:            CSCO_WEBVPN_PASSWORD
isUtf8:                   1
http://internal-mail-server-ip/owa/auth/owaauth.dll]]>
destination
flags
forcedownlevel
trusted
username
password
isUtf8
Greets,
Norbert
Hope this help....please rate if helpful
Overall Rating: 5 (2 ratings)
alig.norbert Mon, 02/28/2011 - 12:04
Have you tried "http capture"?
Here is my "Workaround" bookmark. I'll post the final bookmark (when I'm back in the office).....
http:///owa
destination:     http:///owa/
flags:               0
forcedownloadlevel:     0
trusted:               0
isUft8:          1
BUT, the weird think is, when I hit the bookmark, the OWA (2010) login screen appears.
After klicking (once) on the "sign in" button on the OWA login page, go back to the WebVPN portal and click a second time on the bookmark the
access to the mailbox account is granted.
The same with the post-plugin.
Greets,
Norbert
jmprats Fri, 03/04/2011 - 03:37
it doesn't work for me. Incorrect credentials
http capture? how can i do that? does it works with https?
thanks
Correct Answer
alig.norbert Fri, 03/04/2011 - 13:41
post-parameter:
flags:                    0
forcedownlevel:    0
trusted:                 0
isUtf8:                   1
destination
flags
forcedownlevel
trusted
username
password
isUtf8
Greets,
Norbert
jmprats Mon, 03/07/2011 - 00:45
Great!
This parameters works for me, too (and with https)
Thank you very much
netbin2009 Fri, 10/28/2011 - 03:05
Hi!
Where can i set these parameter setting suggested? I´m using ASA5510 Version 8.4(1) and the post options i have in drop-down list is:
Is this done via cli? If so how should i enter config mode for a specific bookmark and entry?
Fredrik
Related Content
