02-18-2011 11:28 AM - edited 03-06-2019 03:37 PM
hi folks
how to reset the 3750 to factory default,a.k.a like the AP Procedure(press butom and hold on)
02-18-2011 11:53 AM
Try this
config t
write erase
yes to confirm
then reload the switch
If you have VLAN's on the switch you will also have to delete the vlan.dat file
delete flash:vlan.dat
yes to confirm
Mike
02-18-2011 12:31 PM
Guys,I mean reset the switch not erase the configuration,the switch was in a stack member an now its with me while am not able to dive to privileging
07-16-2015 02:02 AM
It is a post of 4 years ago. however, occasionally I just got the answer and leave it here as reference:)
For 3750, in short:
hold the "mode" reset button up to 15 seconds or more till only one system green light.
Then release it, the green light will blink.
"Release the Mode button after approximately 15 seconds when the SYST LED turns solid green. When you release the Mode button, the SYST LED blinks green."
check the console, you will find:
00:11:48: %SYS-7-NV_BLOCK_INIT: Initialized the geometry of nvram
00:11:49: %SYS-5-RELOAD: Reload requested Reload Reason: power-on.
Base ethernet MAC Address: ac:a0:16:5e:27:00
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
flashfs[0]: 502 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32514048
More detail:
http://www.cisco.com/c/en/us/support/docs/routers/2600-series-multiservice-platforms/22188-pswdrec-2600.html
02-18-2011 11:55 AM
Hi Ibrahim,
Steps to reset switches to default are are available at
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800c4546.shtml
Cheers,
Shashank
