Best practise for log configuratin and backup in ASA5505
Answered Question
Feb 20th, 2011
Hi experts.........
I like to take log backup in ASA.. and i like to check whether any attack pattern is there?? how could i do this...???
Also how could i do a best practise for this???
Thanks&Regards
Vipin
Correct Answer by csaxena about 6 years 5 months ago
Vipin,
To add further, here is the configuration guide to configure Syslog Collector:
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/monitor_nsel.html#wp1118451
To the same using ASDM, please refer to this document:
https://supportforums.cisco.com/docs/DOC-6114
In past, i have used Kiwi(freeware), Solar Winds Orion & Cisco MARS(http://www.cisco.com/en/US/products/ps6241/index.html). Please understand these just a few suggestions and not Cisco recommendations
Hope this helps. Please reply if you need further assistance.
Chirag
P.S.: Please mark this thread as answered if you feel your query is answered. Do.rate helpful posts.
Overall Rating: 3.8 (9 ratings)
csaxena Mon, 02/21/2011 - 00:08
  • Cisco Employee,
Hello Vipin,
To acheive the same you can send syslogs from the ASA to an external server. You can either us freeware/third party solutions or Cisco MARS to do the needful.
Chirag
Correct Answer
csaxena Mon, 02/21/2011 - 00:16
  • Cisco Employee,
Vipin,
Chirag
vipinrajrc Mon, 02/21/2011 - 18:28
csaxena wrote:
Vipin,
Chirag
Hi Chirag
Tanks for your reply & sorry for my late reply.
Is kiwi syslog server is free????? Did you work with any of syslog servers??? please share that also if any..........
Thanks&Regards
Vipin Raj
csaxena Mon, 02/21/2011 - 18:39
  • Cisco Employee,
This is the link for Kiwi Syslog Server :
http://www.solarwinds.com/products/freetools/kiwi_syslog_server/
I have worked on Orion, Kiwi and MARS. MARS being more extensive. Please let me know if you looking forward for some specific information.
Chirag
P.S.: Please mark this thread as answered if you feel your query is answered. Do rate helpful posts.
vipinrajrc Mon, 02/21/2011 - 19:31
Chirag
Hi Chirag,
Kiwi is free right?? I have orion NPM.. it is in our environment.... what about MARS?? is it free or paid???
Thanks&Regards
Vipin
Akhil B Mon, 02/21/2011 - 19:56
  • Cisco Employee,
Hi Vipin,
Kiwi is a free syslog application. However CISCO MARS is a paid service.MARS is Monitoring, Analysis and Response system, which is a separate hardware in itself, which you will have to buy.
I have attached the link for MARS, it gives a brief overview on CISCO MARS.
Hope you find the link useful.
Akhil
csaxena Mon, 02/21/2011 - 20:00
  • Cisco Employee,
Thanks Akhil for sharing the same. Vipin if you have Orion NPM then that should do the job for you.
Chirag
vipinrajrc Mon, 02/21/2011 - 20:11
Hi Akhil/Chiraj,
Thanks for your reply....
Vipin
csaxena Mon, 02/21/2011 - 20:17
  • Cisco Employee,
Your welcome Vipin. Please mark the post "Answered" for other to refer it in future.
Chirag
vipinrajrc Sun, 02/27/2011 - 19:49
I am going to implement Kiwi syslog server in my organization.
Do i need to configure levelof logging to ---> informational or error ?????????????
All i need to backup logs and check for any attack pattern in ASA.......... so please suggest a suitable answer............ASAP...
Vipin
csaxena Mon, 02/28/2011 - 00:36
  • Cisco Employee,
Hello Vipin,
Glad to hear that your implementing this.
Here is guide which talks about all the syslogging security levels and its description.
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/monitor_syslog.html#wp1082848
Chirag
