02-23-2011 10:22 PM - edited 03-04-2019 11:32 AM
Hi if somebody is able to sanity check the following QoS config thanks.
My goal is to guarantee 180Kb of bandwidth for voice across each of 2Mb/s WAN links.
The policy maps would be applied outbound on the CPE WAN interfaces, and the AR edge sub-interfaces to the Service Provider. Unfortunately the Service Provider does not support 802.p
ip access-list extended VOIP-TRAFFIC
permit udp any any eq 5060
permit tcp any any eq 5060
permit udp any any range 10000 20000
class-map match-any VOIP
match access-group name VOIP-TRAFFIC
policy-map OUTBOUND
class VOIP
priority 180
class class-default
fair-queue
** CPE Site A & B
interface e0
service-policy output OUTBOUND
** AR
interace Gi0.1 & Gi0.2
Solved! Go to Solution.
02-23-2011 10:28 PM
that's fine for the E1 interfaces, but on the gig subints you should also shape:
policy-map SHAPE
class class-default
shape average 2000000
service-policy OUTBOUND
int gig0.1
service-policy output SHAPE
02-23-2011 10:28 PM
policy-map SHAPE
class class-default
int gig0.1
