Cisco 1700 Password reset
Answered Question
Mar 4th, 2011
I need some help with the password reset of a Cisco 1700 Router, when I do a :
rommon 1 > confreg 0x2102
rommon 2 >
I do not receive the message / prompt to reboot, and once I type reset the router just boots as per normal, please help.
Correct Answer by Alen Danielyan about 6 years 1 month ago
You have to do this:
- change register to 2142 (not 2102)
- reset
- allow normal boot, enter in EXEC mode and change your password (Attention! If you were using "secret" passwords, you can only change it and thus save the new config. So you will lose your real config. If you have a backup - no problem).
- change register to 2102 by "config-register 0x2102" in EXEC mode.
- Reload the router
- Use new credentials and configure your router as it should be.
Overall Rating: 5 (1 ratings)
Correct Answer
Alen Danielyan Sun, 03/06/2011 - 01:54
- reset
- Reload the router
