03-10-2011 05:09 AM - edited 03-11-2019 01:04 PM
Hi!
Can the ASA firewall be used to perform intervlan routing in the same way that a router would be used. (Router-on-a-stick).
Alvin
Solved! Go to Solution.
03-10-2011 05:20 AM
03-10-2011 06:20 AM
03-11-2011 11:38 AM
is your question clear?
03-10-2011 05:20 AM
Yes you can
03-10-2011 06:20 AM
03-11-2011 11:38 AM
