VPN does NOT work in SOME Hotel NetWorks ?!?
Mar 11th, 2011
Any idea why in some places I can not switch on my VPN ?
The strange thing is when I use the VPN server of my office , this work OK and it is the same VPN client.
So this means that I do something wrong in my private CISCO 1841 ROUTER.
Here bellow what does not work and at the bottom the same computer same network , but other VPN server :
Cisco Systems VPN Client Version 5.0.03.0560
Copyright (C) 1998-2007 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 2
36     10:13:40.625  03/11/11  Sev=Info/4 CM/0x63100002
Begin connection process
37     10:13:40.640  03/11/11  Sev=Info/4 CM/0x63100004
Establish secure connection
38     10:13:40.640  03/11/11  Sev=Info/4 CM/0x63100024
Attempt connection with server "mlgw.dyndns.info"
39     10:13:40.718  03/11/11  Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with 81.83.201.32.
40     10:13:40.734  03/11/11  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to 81.83.201.32
41     10:13:40.984  03/11/11  Sev=Info/4 IPSEC/0x63700008
IPSec driver successfully started
42     10:13:40.984  03/11/11  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
43     10:13:45.984  03/11/11  Sev=Info/4 IKE/0x63000021
Retransmitting last packet!
44     10:13:45.984  03/11/11  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (Retransmission) to 81.83.201.32
45     10:13:50.984  03/11/11  Sev=Info/4 IKE/0x63000021
46     10:13:50.984  03/11/11  Sev=Info/4 IKE/0x63000013
47     10:13:55.984  03/11/11  Sev=Info/4 IKE/0x63000021
48     10:13:55.984  03/11/11  Sev=Info/4 IKE/0x63000013
49     10:14:00.984  03/11/11  Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=0EACC63815AC9551 R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
50     10:14:01.484  03/11/11  Sev=Info/4 IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=0EACC63815AC9551 R_Cookie=0000000000000000) reason = DEL_REASON_PEER_NOT_RESPONDING
51     10:14:01.484  03/11/11  Sev=Info/4 CM/0x63100014
Unable to establish Phase 1 SA with server "mlgw.dyndns.info" because of "DEL_REASON_PEER_NOT_RESPONDING"
52     10:14:01.484  03/11/11  Sev=Info/5 CM/0x63100025
Initializing CVPNDrv
53     10:14:01.484  03/11/11  Sev=Info/6 CM/0x63100046
Set tunnel established flag in registry to 0.
54     10:14:01.484  03/11/11  Sev=Info/4 IKE/0x63000001
IKE received signal to terminate VPN connection
55     10:14:01.500  03/11/11  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
56     10:14:01.500  03/11/11  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
57     10:14:01.500  03/11/11  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
58     10:14:01.500  03/11/11  Sev=Info/4 IPSEC/0x6370000A
IPSec driver successfully stopped
THIS WORK OK :
59     10:25:37.953  03/11/11  Sev=Info/4 CM/0x63100002
60     10:25:38.203  03/11/11  Sev=Info/4 CM/0x63100004
61     10:25:38.203  03/11/11  Sev=Info/4 CM/0x63100024
Attempt connection with server "193.89.221.13"
62     10:25:38.265  03/11/11  Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with 193.89.221.13.
63     10:25:38.359  03/11/11  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG (SA, KE, NON, ID, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to 193.89.221.13
64     10:25:38.437  03/11/11  Sev=Info/4 IPSEC/0x63700008
65     10:25:38.437  03/11/11  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
66     x0:25:38.437  03/11/11  Sev=Info/5 IKE/0x6300002F
Received ISAKMP packet: peer = 1x3.89.221.13
67     10:25:38.437  03/11/11  Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK AG (SA, KE, NON, ID, HASH, VID(Unity), VID(Xauth), VID(dpd), VID(Nat-T), NAT-D, NAT-D, VID(Frag), VID(?)) from 193.89.221.13
68     10:25:38.437  03/11/11  Sev=Info/5 IKE/0x63000001
Peer is a Cisco-Unity compliant peer
69     10:25:38.437  03/11/11  Sev=Info/5 IKE/0x63000001
Peer supports XAUTH
70     10:25:38.437  03/11/11  Sev=Info/5 IKE/0x63000001
Peer supports DPD
71     10:25:38.437  03/11/11  Sev=Info/5 IKE/0x63000001
Peer supports NAT-T
72     10:25:38.437  03/11/11  Sev=Info/5 IKE/0x63000001
Peer supports IKE fragmentation payloads
73     10:25:38.703  03/11/11  Sev=Info/6 GUI/0x63B00012
Authentication request attributes is 87h.
74     10:25:38.468  03/11/11  Sev=Info/6 IKE/0x63000001
IOS Vendor ID Contruction successful
75     10:25:38.468  03/11/11  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK AG *(HASH, NOTIFY:STATUS_INITIAL_CONTACT, NAT-D, NAT-D, VID(?), VID(Unity)) to 1x3.89.221.13
76     10:25:38.500  03/11/11  Sev=Info/6 IKE/0x63000055
Sent a keepalive on the IPSec SA
77     10:25:38.500  03/11/11  Sev=Info/4 IKE/0x63000083
IKE Port in use - Local Port =  0x0584, Remote Port = 0x1194
78     10:25:38.500  03/11/11  Sev=Info/5 IKE/0x63000072
Automatic NAT Detection Status:
   Remote end is NOT behind a NAT device
   This   end IS behind a NAT device
79     10:25:38.500  03/11/11  Sev=Info/4 CM/0x6310000E
Established Phase 1 SA.  1 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
80     10:25:38.515  03/11/11  Sev=Info/5 IKE/0x6300002F
81     10:25:38.531  03/11/11  Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ATTR) from 193.89.221.13
82     10:25:38.531  03/11/11  Sev=Info/4 CM/0x63100015
Launch xAuth application
83     10:25:47.078  03/11/11  Sev=Info/4 CM/0x63100017
xAuth application returned
84     10:25:47.078  03/11/11  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to 1x3.89.221.13
85     10:25:47.140  03/11/11  Sev=Info/5 IKE/0x6300002F
Received ISAKMP packet: peer = 193.89.221.13
86     10:25:47.140  03/11/11  Sev=Info/4 IKE/0x63000014
87     10:25:47.140  03/11/11  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to 193.89.221.13
88     10:25:47.140  03/11/11  Sev=Info/4 CM/0x6310000E
Established Phase 1 SA.  1 Crypto Active IKE SA, 1 User Authenticated IKE SA in the system
89     10:25:47.453  03/11/11  Sev=Info/5 IKE/0x6300005E
Client sending a firewall request to concentrator
90     10:25:47.468  03/11/11  Sev=Info/4 IKE/0x63000013
91     10:25:47.937  03/11/11  Sev=Info/5 IKE/0x6300002F
92     10:25:47.937  03/11/11  Sev=Info/4 IKE/0x63000014
This SA has already been alive for 10 seconds, setting expiry to 86390 seconds from now
Thank you in advance for your help,
Best Regards,
Didier
Overall Rating: 4 (3 ratings)
Yudong Wu Fri, 03/11/2011 - 09:19
  • Gold, 750 points or more
From client log, you could see "Retransmitting last packet!" and "DEL_REASON_PEER_NOT_RESPONDING".
So, you need run a debug on your home router to see if it receives IKE negociation packet. If yes, why it did not reply it.
Didier1966 Sat, 03/12/2011 - 01:19
Thank you for your prompt reply
What kind of debug do you recommend I can put ON , to follow up on this ?
I have put on this one :
ROUTER1841_1#debug vpn authorization event
Best Regards,
Didier
Yudong Wu Sat, 03/12/2011 - 20:28
Please run the following two debug.
debug crypto isa
debug crypto ipsec
Didier1966 Sun, 03/13/2011 - 11:47
Thank You for your HELP
I have a other small question not directly related to this , but to the monitor part.
The problem I have , I can see the LOG when I am connected directly to my router via the CONSOL RS232 connector.
How can I see this monitoring when I use TELNET or SSH ?
A plan B can be to leave a computer connected directly to the ROUTER , while a other computer try to connect via VPN.
But I think their is a way to save or see the LOG while we are in TELNET or SSH mode , but I do not know how
Any idea is welcome
Best Regards,
Didier.
Yudong Wu Sun, 03/13/2011 - 18:16
try "terminal monitor"
make sure the logging level for monitor session is set to debugging -- "logging monitor debug"
You can also increase you logging biffer size "logging buffered 2000000" - 2M
and then check your buffer logging by 'show log"
Didier1966 Mon, 03/14/2011 - 07:55
Thank you for this useful information , I have just put it ON , now I just have to wait.
Best Regards,
Didier
