upgrade 7.0.2.20000-5 to 7.X
Answered Question
Mar 14th, 2011
hello,
We buy a call manager and the version is 7.0.2.20000-5 so wich version we can upgrade we are looking upgrede to 7.X not 8.X
Waht is the major version 7.X I can upgrade?
another question  what is the diferent between:
Export Restricted Cisco Unified Communications Manager Release 7.1(5x)
and
Cisco Unified Communications Manager Release 7.1(3x)
more information in:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp43011
Export Restricted Cisco Unified Communications Manager Release 7.1(5x)—Table 8
Export Unrestricted Cisco Unified Communications Manager Release 7.1(4x) through 7.1(5x)—Table 11
Cisco Unified Communications Manager Release 7.1(3x)—Table 14
Cisco Unified Communications Manager Release 7.1(2x)—Table 15
Cisco Unified Communications Manager Release 7.0(x)—Table 16
Correct Answer by Rob Huffman about 3 years 1 month ago
Hi Oscar,
There is not a nice chart that shows the differences, but they can be seen
in the version release notes
Release Notes for Cisco Unified Communications Manager Release 7.1(3b)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_3/cucm-rel_notes-713b.html
Release Notes for Cisco Unified Communications Manager Release 7.1(5b)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_5/cucm-rel_notes-715b.html
Cheers!
Rob
Average Rating: 5 (3 ratings)
Jaime Valencia Mon, 03/14/2011 - 11:02
You already have the compatibility matrix so that pretty much answers your question of which version you can go.
Take some time to review which version you want to go and determine if it's a 1 jump or a 2 jump process.
As for restricted and unrestricted.
Restricted is the regular CUCM version that has all the security features enabled.
Unrestricted doesn't have the ability to authenticate and/or encrypt signaling nor media.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
maucorpat Tue, 03/15/2011 - 05:22
so for my case I can upgrade from 7.0 to
Im afraid this export Restricted, i dont know if is working fine. We will not need encrypt any media or call.
but we wants the latest that probably have not bugs.
what do you thing? from 7.0 at wich you will upgrade?
thanks a lot...
Rob Huffman Tue, 03/15/2011 - 05:30
Hi Oscar,
You will want to go for the Restricted version due to the upgrade
limitations placed on "Unrestricted" versions. Many people here
still find this version as the most stable of all the 7.x builds;
Table 14     Supported Cisco Unified Communications Manager Upgrades for Release 7.1(3x)
7.1(3b)SU2
7.1(3b)SU1
7.1(3b)
7.1(3a)SU1a
7.1(3a)SU1
7.1(3a)
7.1(3)
System Version
7.1.3.32900-4
7.1.3.31900-1
7.1.3.30000-1
7.1.3.21901-1
7.1.3.21900-4
7.1.3.20000-2
7.1.3.10000-11
Release Date
Feb 18 2010
Dec 15 2009
Dec 15 2009
Dec 8 2009
Dec 1 2009
Nov 4 2009
Sep 22 2009
Standard Support
Direct upgrade:
7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3)
Direct upgrade:
Direct upgrade:
7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 5.1(3g), 5.1(3f), 5.1(3e)1, 5.1(3d), 5.1(3c), 5.1(3b), 5.1(3a), 5.1(3)
Direct upgrade:
Direct upgrade:
Direct upgrade:
7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 5.1(3g), 5.1(3f), 5.1(3e)1 , 5.1(3d), 5.1(3c), 5.1(3b), 5.1(3a), 5.1(3)
Direct upgrade:
Direct upgrade using DMA:
none
none
4.3(2), 4.2(3), 4.1(3)
none
none
If you are going with 7.1(5), I would move straight to this version;
Table 8     Export Restricted Supported Cisco Unified Communications Manager Upgrades for Release 7.1(5b) through 7.1(5x)
7.1(5b)SU3
7.1(5b)SU2
7.1(5b)
System Version
7.1.5.32900-2
7.1.5.31900-3
7.1.5.30000-1
Release Date
Dec 16 2010
Aug 10 2010
Jul 20 2010
Standard Support
Direct upgrade:
7.1(5b)SU2(restricted), 7.1(5b)(restricted), 7.1(5a)(restricted), 7.1(5)SU1a(restricted), 7.1(5)SU1(restricted), 7.1(5)(restricted), 7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(5)SU3, 6.1(5)SU2, 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3)
Direct upgrade:
Direct upgrade:
7.1(5a)(restricted), 7.1(5)SU1a(restricted), 7.1(5)SU1(restricted), 7.1(5)(restricted), 7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(5)SU3, 6.1(5)SU2, 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 5.1(3g), 5.1(3f), 5.1(3e)1 , 5.1(3d), 5.1(3c), 5.1(3b), 5.1(3a), 5.1(3)
none
none
Cheers!
Rob
maucorpat Tue, 03/15/2011 - 05:48
thanks.
I think I will go with the 7.1(3b)SU2. there are some place where we can see the diferences between thesse two realeaces?
Correct Answer
Rob Huffman Tue, 03/15/2011 - 05:56
Hi Oscar,
Cheers!
Rob
Login or Register to take actions
Posted March 14, 2011 at 10:55 AM
Stats:
Replies:5 Avg. Rating:5
Views:371 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
