03-18-2011 09:55 PM - edited 03-06-2019 04:09 PM
I have a very basic question.
Who is responsible of maintaining the ARP Cache and to provide the Destination MAC Address to the Data Link Layer?
I know that ARP at Layer 3 is used to map the IP Addresses to unknown MAC Addresses. But after recieving the ARP Reply from it's peer, to whom does ARP provide this MAC Address? Does it forward it directly to the Data Link Layer or to someone else?
Best Regards,
Daud Parvez
03-19-2011 02:27 AM
Hi Daud,
# Who is responsible of maintaining the ARP Cache and to provide the Destination MAC Address to the Data Link Layer?
ARP cache will be maintained by the PC and the Router or switch.
# I know that ARP at Layer 3 is used to map the IP Addresses to unknown MAC Addresses. But after recieving the ARP Reply from it's peer, to whom does ARP provide this MAC Address? Does it forward it directly to the Data Link Layer or to someone else?
Let's say that a PC wants to communicate with server 10.10.10.10. It must first resolve the IP address to the MAC address. To do this, it does an ARP request. This is a broadcast to the local LAN that says who has IP address 10.10.10.10 and what is your MAC address?
Server responds and says I have IP address 10.10.10.10 and my MAC address is 1234.4567.890A.
>>> The PC will put that entry into its local ARP cache and it will stay there until the entry has not been used and the ARP cache timeout has expired.
you can check for ARP cache in ur PC: arp -a
sim.. Router / MLS switch will also keep a track of these entries by maintaining a ARP cache.
sh ip arp .. to see the mapping.
Routers/switches arp cache generally have a default timeout of 4 hours . while for PC it wud be 5 minutes.
Besr Regards,
Sandeep
03-19-2011 09:32 AM
Hello Sandeep,
You are absolutely correct in what you wrote. However, I tend to believe that Daud's question was also concerned with a more obscure fact: who is using the ARP cache? Is it the IP driver or the Ethernet NIC driver?
From a pure theoretical and OSI-layered view, it's a kind of enigma: the IP should be agnostic about the data link layer and its specifics, and the Ethernet is not supposed to understand the IP specifics.
In reality, there must be an adaptation (or a convergence) sublayer present between the IP and the Ethernet driver that actually allows the IP to work over a specific data link layer technology, in this case, the Ethernet. The ARP belongs, in my opinion, to the category of L3 management protocols (I know that talking about the layer into which the ARP protocol belongs is starting a holy war - I don't plan to do anything similar here). The IP driver is the one which is using the ARP cache, and by means of the adaptation sublayer, it is able to also pass the L2 addressing information to the lower layer when sending a packet.
My two cents on this... Any other opinions are welcome!
Best regards,
Peter
03-19-2011 10:13 AM
Thanks both for your replies.
Dear Peter,
As far as i have understood from your reply, it is the duty of the Network Layer to provide the Destination MAC Address to the Data Link Layer?
Can you please explain it a bit further?
Best Regards,
Daud Parvez.
03-20-2011 04:16 AM
Hello Daud,
The OSI reference model is often explained in terms of individual layers being independent of each other. That is true to a certain point. If you think about it a little more you will find out that the layer N cannot be totally unaware of specifics of layer N-1 because it would prevent them from actually cooperating together.
The dilemma of ARP is a nice example. The IP itself is quite ignorant of any data link layer technology - it just does not care. However, once an IP driver sends an IP packet, it cannot be so ignorant anymore because the packet needs to be encapsulated in a frame with a proper addressing information. In order to make this IP-over-Ethernet thing work, there must be an element on the path between the network and data link layer that actually understands both IP and Ethernet specifics. Thus, in an IP driver implementation, there must a data link layer-specific part that adapts the IP to work over a particular link layer technology, in this case, the Ethernet.
You surely remember that the Ethernet itself is often depicted as consisting of two sublayers - the higher LLC (Logical Link Control), and the lower MAC (Media Access Control). The LLC is actually the functionality of Ethernet that allows us to multiplex several different payload types over Ethernet frames, carry user data, even make the Ethernet to provide connection-oriented data transfers (although I've never seen this feature implemented). However, there are various physical standards of the Ethernet available which is the reason why the MAC layer is present - to adapt the transmission of Ethernet frames over diverse media and access methods. In effect, there is a media-independent part, and a media-dependent part.
With the IP, although it may not be so visible in terms of layering, it's the same: there must be a data link layer-specific part in the actual IP driver, or at least the IP driver must have the ability to select an appropriate IP-to-L2 mapping database and pass the L2 address to the NIC driver (without actually understanding what the L2 information is - whether it is a MAC address, DLCI, VPI/VCI etc.). In essence, there must be a part of the IP driver adapted to particular data link technology. In the software engineering, this may be done nicely by utilizing a modular software design and software interfaces.
Best regards,
Peter
