WLC 4400 Files
Mar 19th, 2011
Hello;
Is there any chance to access files on 4400 with ssh (winscp etc.) clients ?
For example we upload webauth bundle and then we want to delete it and recopy another files...how can i do this ?
Umut
Overall Rating: 5 (1 ratings)
Surendra BG Sat, 03/19/2011 - 23:15
  • Cisco Employee,
The bundle which we download on the WLC will be  unzipped and used.. so there is no way we can get the copy of the same,  If you want the new bundle to be used, then at the time we upload the  bundle on to the WLC, the old one will be overwritten by the new..
Surendra
CSCO11177789 Sun, 03/20/2011 - 00:55
Hello;
Let me clarify, when we upload weauth bundle as a *.tar file with the same name, it replace old one ... But we can use different webauth bundles for different guest wlan ids. So i need to know,if  it replace all the time without looking same name or not ?
Thanks.
Umut
Surendra BG Sun, 03/20/2011 - 02:01
  • Cisco Employee,
The files are overwritten when you upload the new TAR bundle up to the controller, you can only have 1 custom bundle installed
per controller, so uploading a new TAR bundle will overrite the old one.
Surendra
Related Content
Trending Topics - Security & Network
