Nicolas Darchis Mon, 03/21/2011 - 13:40
Why would anyone desire to do LEAP on Windows 7 ?
LEAP is known to be unsecure and if you have the chance to do eap-fast, you shouldn't be doing LEAP
nowiressecurity Wed, 03/23/2011 - 08:41
Yes, I agree. Just researching for an article I'm doing on third-party supplicants. It was hard to find info on the EAP-FAST module, but I can't find the EAP-LEAP module anywhere.
dmantill Wed, 03/23/2011 - 13:39
Well you can try this:
http://blogs.msdn.com/b/eapteam/archive/2008/10/17/how-do-i-install-cisco-eap-fast-on-my-computer.aspx
http://blogs.msdn.com/b/eapteam/archive/2008/10/17/how-can-i-download-the-ecp-methods-from-the-web.aspx
however I dont know if it is needed, but on my computer I already have LEAP EAPFAST and cisco PEAP
From intel, EAP-SIM, EAP-TTLS and EAP-AKA
Im running Windows 7 ultimate
I can see these options on WZC when I am setting up the security options on the profile.
I recently downloaded the wireless drivers for my Intel 3945ABG wireless card. So I cant really explain if there were since the begining or thru a windows update or maybe due to the manually updated Intel drivers...
Hope it helps you
nowiressecurity Thu, 03/24/2011 - 06:40
http://blogs.msdn.com/b/eapteam/archive/2008/10/17/how-do-i-install-cisco-eap-fast-on-my-computer.aspx This shows just how to install EAP-FAST, which works for me.
http://blogs.msdn.com/b/eapteam/archive/2008/10/17/how-can-i-download-the-ecp-methods-from-the-web.aspx I can find "ECPNode" via the Windows Update site but only installs EAP-FAST
Yeah, I've read that some people find EAP-LEAP and/or EAP-FAST installed automatically by I think Windows Update.
Does the wireless adapter have to specifically support these EAP protocols? maybe that's the problem.
Related Content
Trending Topics - Security & Network
