ASA 8.4 - Static NAT - Problem with outbound SMTP
Answered Question
Mar 31st, 2011
Below is the interesting part of my config.  I have static NAT configured and working inbound for the Exchange Server and the Barracuda, however outbound traffic from those hosts comes out as the interface IP.  Thoughts?  I've tried a number of things (outside, inside), etc...  No luck.  Any help would be appreciated.
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network DSN-EXCH01
host 10.250.231.51
object network MAIL-IN
host 10.250.231.50
access-list outside_inside extended permit tcp any host 10.250.231.51 eq https
access-list outside_inside extended permit tcp any host 10.250.231.51 eq www
access-list outside_inside extended permit tcp any host 10.250.231.50 eq smtp
nat (inside,outside) source dynamic any interface
nat (inside,outside) dynamic interface
nat (inside,outside) static xxx.xxx.xxx.25
nat (inside,outside) static xxx.xxx.xxx.26
access-group outside_inside in interface outside
Correct Answer by Shrikant Sundaresh about 6 years 3 weeks ago
The issue here is with the order of NAT rules in the 8.4 version.
A Manual NAT rule takes precedence over Auto NAT (within object group).
So, nat (inside,outside) source dynamic any interface; is taking precedence when going from inside to outside.
I hope this helps.
-Shrikant
PS: Please mark the question resolved, if it has been answered. Do rate helpful posts. Thanks
Overall Rating: 5 (1 ratings)
Correct Answer
Shrikant Sundaresh Thu, 03/31/2011 - 11:09
  • Cisco Employee,
I hope this helps.
-Shrikant
clamasters Thu, 03/31/2011 - 11:52
That makes sense, thank you. Is there a better way to acomplish this then?  I see there are some options to insert rules before and after other parts of NAT but not sure what to use just yet.
Thank you,
Curtis
clamasters Thu, 03/31/2011 - 11:56
Actually, I just removed that part of the config since I already had an object NAT configured for 0.0.0.0.
Thank you very much.
Related Content
