2960(S) HSRP support
Apr 1st, 2011
Hi, the 2960 series  with LAN Base image now supports a limited L3-routing functionality.
I tried to test if HSRP also works, and surprise, it works.
Because I do not find any document with infos thats HSRP is official supported on the 2960, does naybody have knowledge
if its officialy supported or it "just" works.
Thx
Hubert
switch#sh sdm prefer
The current template is "lanbase-routing" template.
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 255 VLANs.
  number of unicast mac addresses:                  4K
  number of IPv4 IGMP groups + multicast routes:    0.25K
  number of IPv4 unicast routes:                    4.25K
    number of directly-connected IPv4 hosts:        4K
    number of indirect IPv4 routes:                 0.25K
  number of IPv4 policy based routing aces:         0
  number of IPv4/MAC qos aces:                      0.125k
  number of IPv4/MAC security aces:                 0.375k
switch#
switch(config)#ip routing
switch(config)#^Z
switch#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C    192.168.199.0/24 is directly connected, Vlan199
     10.0.0.0/24 is subnetted, 4 subnets
C       10.10.100.0 is directly connected, Vlan300
C       10.10.101.0 is directly connected, Vlan301
C       10.10.102.0 is directly connected, Vlan302
C       10.10.103.0 is directly connected, Vlan303
switch#
interface Vlan300
ip address 10.10.100.1 255.255.255.0
standby 100 ip 10.10.100.254
standby 100 priority 200
standby 100 preempt delay minimum 60
interface Vlan301
ip address 10.10.101.1 255.255.255.0
standby 101 ip 10.10.101.254
standby 101 priority 200
standby 101 preempt delay minimum 60
interface Vlan302
ip address 10.10.102.1 255.255.255.0
standby 102 ip 10.10.102.254
standby 102 priority 200
standby 102 preempt delay minimum 60
interface Vlan303
ip address 10.10.103.1 255.255.255.0
standby 103 ip 10.10.103.254
standby 103 priority 200
standby 103 preempt delay minimum 60
switch#sh stand brief
                     P indicates configured to preempt.
Interface   Grp  Pri P State   Active          Standby         Virtual IP
Vl300       100  200 P Active  local           10.10.100.2     10.10.100.254
Vl301       101  200 P Active  local           10.10.101.2     10.10.101.254
Vl302       102  200 P Active  local           10.10.102.2     10.10.102.254
Vl303       103  200 P Active  local           10.10.103.2     10.10.103.254
switch#
router#sh stand brief
Vl300       100  150 P Standby 10.10.100.1     local           10.10.100.254
Vl301       101  150 P Standby 10.10.101.1     local           10.10.101.254
Vl302       102  150 P Standby 10.10.102.1     local           10.10.102.254
Vl303       103  150 P Standby 10.10.103.1     local           10.10.103.254
router#
switch#sh ver
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(55)SE1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 02-Dec-10 08:16 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01800000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(35r)SE2, RELEASE SOFTWARE (fc1)
switch uptime is 56 minutes
System image file is "flash:/c2960-lanbasek9-mz.122-55.SE1/c2960-lanbasek9-mz.122-55.SE1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C2960G-8TC-L (PowerPC405) processor (revision A0) with 65536K bytes of memory.
Processor board ID FOC1331V58Q
Last reset from power-on
6 Virtual Ethernet interfaces
8 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:26:CA:8C:20:00
Motherboard assembly number     : 73-10613-08
Power supply part number        : 341-0208-01
Motherboard serial number       : FOC13311MZK
Power supply serial number      : LIT132806DR
Model revision number           : A0
Motherboard revision number     : B0
Model number                    : WS-C2960G-8TC-L
System serial number            : FOC1331V58Q
Top Assembly Part Number        : 800-28133-01
Top Assembly Revision Number    : E0
Version ID                      : V01
CLEI Code Number                : COM7S00ARA
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 8     WS-C2960G-8TC-L    12.2(55)SE1           C2960-LANBASEK9-M
Configuration register is 0xF
switch#
Richard Burts Tue, 04/05/2011 - 21:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hubert
I used the Feature Navigator from the Cisco web site (www.cisco.com/go/fn) to find the features supported in your version of code for the 2960. According to the Feature Navigator HSRP is an officially supported feature in your version of code for the 2960.
Rick
HUBERT RESCH Tue, 04/05/2011 - 23:28
Hi Richard,
I know that feature navigator shows HSRP as supported with 2960, but to be honest FN ist not always perfekt and configuring HSRP on the
SVI cannot be found in any 2960 configuration guide!?!
So I am afraid that it "just" works ?
KR
Hubert
karel.pouzar Wed, 09/21/2011 - 01:39
Configuration of HSRP on pair of standalone 2960-S under 12.2.55SE2 caused instability and reloads of catalysts early after deployment. We must remove it from configuration.
Answer from Cisco BU was: HSRP is not supported feature on 2960-S.
Best Regards
Karel
Alexander Maroukian Wed, 09/21/2011 - 03:00
  • Bronze, 100 points or more
Hi Hubert,
I do not see this feature (HSRP) listed in Cisco feature navigator for catalyst 2960 line. I tried it over a year ago on 2960 and as Karel writes it caused instability issues. And yes it is just working, maybe for some configurations and topologies (needs extensive testing, which I have not perform). I would not recommend for production network.
Alex
glen.grant Wed, 09/21/2011 - 05:04
  • Purple, 4500 points or more
   That is true just because it was left in the code doesn't mean its supported.  I remember on some Cat 4500's with SupII pluses with ipbase software you  could get BGP to work and peer with other devices but it was not supported .
