04-05-2011 03:33 PM
Hi guys
Is there a way to do this? I cant find anywhere how to configure the AAA parameters for the ACE CLI access using the ANM. I know where to configure AAA for the ANM access, but not for the ACE devices.
thx in advance!
Omar M
Solved! Go to Solution.
04-06-2011 07:31 AM
Hi Omar,
I'm afraid this is one of the few things that can only be configured through the CLI of the ACE.
Daniel
04-06-2011 07:31 AM
Hi Omar,
Daniel
04-06-2011 08:01 AM
Thank you Daniel!
04-06-2011 09:27 AM
Another quick question!
Is there a way to change the interface that the ACE uses for TACACSs requests? Also, there's gonna be a request for each context right?
04-07-2011 04:34 AM
Hi Omar,
The interface to be used for the AAA request is chosen based on the routing table, so, unless the server is in a vlan directly connected to the ACE, you can define which interface to be used by configuring a static route towards the server.
The AAA configuration is done on a per-context basis, so, each context will handle connections arriving to it following its own configuration settings.
