Port channel interface created and "show int status", It put into vlan 0?
Apr 9th, 2011
Dears,
I create one etherchannel, and It is disconnect.
But I command "show int status", the etherchannel vlan status put into vlan "0".
My device is C6506 / IOS : ipservice. SXF10.
Config:
interface Port-channel51
switchport
switchport mode trunk
no ip address
interface GigabitEthernet2/41
switchport
no ip address
channel-group 51 mode on
interface GigabitEthernet2/42
switchport
no ip address
Status:
show int status
Port    Name Status       Vlan          Duplex Speed Type
Po51    xxxx notconnect   0             full   auto
Gi2/41  xxxx notconnect   1             full   1000 10/100/1000BaseT
Gi2/42  xxxx notconnect   1             full   1000 10/100/1000BaseT
Thanks.
Reza Sharifi Sat, 04/09/2011 - 07:42
  • Cisco Designated VIP,
    2017 LAN
Are physical inerfaces gi2/41 and gi2/42 in up an up mode?
Can you change "channel-group 51 mode on" to "channel-group 51 mode desirable" on both sides of the Etherchannel and test again?
Reza
mr.marslin Sat, 04/09/2011 - 08:50
Dear Sir,
Now all link is down.
I already to remove the port-channel command, and setup again.
But the port-channel still put into vlan 0.....
