ASA 5505 error
ccnpwannabe
%ERROR: csco_config.lua:39: csco_config.lua:656: copying 'disk0:/csco_config/locale/fr/LC_MESSAGES/csd.po' to a temporary ramfs file failed
%ERROR: csco_config.lua:331: csco_config.lua:39: csco_config.lua:11423: copying 'disk0:/csco_config/97/plugin/post' to ramfs file '/plugin_.KDOAAA' failed
%ERROR: csco_config.lua:331: csco_config.lua:39: csco_config.lua:11423: copying 'disk0:/csco_config/97/plugin/vnc' to ramfs file '/plugin_.MYMAAA' failed
%ERROR: csco_config.lua:331: csco_config.lua:39: csco_config.lua:11423: copying 'disk0:/csco_config/97/plugin/ssh,telnet' to ramfs file '/plugin_.PVKAAA' failed
%ERROR: csco_config.lua:331: csco_config.lua:39: csco_config.lua:11423: copying 'disk0:/csco_config/97/plugin/rdp' to ramfs file '/plugin_.UNOAAA' failed
[ERROR] revert webvpn url-list ACCESS
    % URL list 'ACCESS' is in use and cannot be reverted
Why do i get this error
Jennifer Halim
Looks like you are having issues with your webvpn configuration.
Are you running webvpn? you might have to remove all the webvpn and start from scratch again.
To remove all the webvpn configure: revert webvpn all
