04-17-2011 04:11 AM - edited 03-14-2019 07:46 AM
Hi All
I need a little assistance in scripting. I am creating a script in UCCX 8.0 which will authenticate a user using the USER ID and PIN info from CAll Manager. What i want to do is to use the Get User info step in UCCX to get the user ID from Call Manager by using the identifier attribute. Then i will collect the PIN by using the GET Digit String and pass both of these to Authenticate user STEP.
somehow this does not seem to work and when i do a reactive debug it gives me error in the get user info step.
Any help will be much appreciated. Attached is the script attached.
02-19-2016 05:04 AM
I am facing the same problem as you. Did you get it resolved ? If yes could you please share with me ?
Luís.
02-19-2016 07:24 AM
Luis, find the answer in your other thread:
https://supportforums.cisco.com/discussion/12918876/how-use-get-user-info-step-while-scripting-uccx-106#comment-11167141
Deepak
