Phones showing engaged when trying to transfer call
Apr 19th, 2011
Our client has 8 SPA504G Phones connected to 2 SR300-28G which is connected to the UC540 (Version 8.1) Via the expansion port. The problem the client is having is that sometimes the users are unable to transfer phone calls between the phones (the phones are showing as engaged (tone) when trying to transfer), the problem has occurred several times and the only way to solve this was to restart everything (switch, UC, phones) and sometimes connect it back to the UC physically so it gets the configuration and then take it back to where it should be.
Are there any patches that solves this problem? Or any suggestions why this is happening?
Mahesh
Overall Rating: 5 (3 ratings)
Steven DiStefano Tue, 04/19/2011 - 07:59
  • Blue, 1500 points or more
We dont have any problems knwon of this nature, but if you search this community you will see that in several cases, this bahavior can result in the phones not getting IPs on the correct Voice VLAN DHCP scope and pool (from the UC540).
While the SG300 is a kick butt switch that received rave reviews fron Tolly reports (crushed competitors), that fact is they dont yet have the FW which supports smart ports or CDP.   So its not plug and play.   One of the really smart guys who writes "Smart Designs"  wrote this Application note for exactly this occasion when our partners run ahead of us a little bit :-)  And I think you for using Cisco.
http://www.cisco.com/web/partners/sell/smb/tools_and_resources/smart_business_comm_system.html
Check that out.   Set it up correcly, and your problems will go away.
Steve
David Trad Tue, 04/19/2011 - 16:10
  • Gold, 750 points or more
  • Cisco Designated VIP,
    2013 Small Business
Hi Steve,
Are you referring to these switches?
http://www.cisco.com/en/US/products/ps10898/prod_models_comparison.html
So these are not designed then to work with the UC-500 as such due to them not supporting CDP? Or do the switches shown above support CDP or will support CDP in an upcoming firmware release?
So to configure these I would imagine you would then need to tag the ports with the respective VLAN's and if they are access or trunk ports then?
Cheers,
David.
David Harper Tue, 04/19/2011 - 20:25
  • Cisco Employee,
CDP plus a few other features that will make the switches much better suited for voice deployments are part of the 1.1 firmware release due out very soon.  CCA support for the 300 series is also in the works, and once that is there, the install experience should be at least as good as you get with the ESW switches.
Cheers,
Dave.
David Trad Tue, 04/19/2011 - 21:16
    2013 Small Business
Hi Dave,
EXCELLENT NEWS!!!!
These switches when compared to others compete on a pound for pound blow, price and quality too boot
I am looking at using these for the UC-320W as they seem like an ideal match, would this be a suitable environment for it?
Cheers,
David.
David Hornstein Tue, 04/19/2011 - 21:27
Hi Dave
I noticed the PM stated in the support  community that the 1.1 software for the 300 is coming out in May.  I am in fact using the 300 series switches on the UC320 at the moment.
I posed the following https://supportforums.cisco.com/docs/DOC-15758  to get it easily configured today.
That posting should be redundant when version 1.1 of the code comes out.
regards Dave
mahesh101 Tue, 04/19/2011 - 23:51
Hi Stephen
I have configured all the phones on Static IP so they do not need to route themselves to get one. can this also be the issue
Mahesh
David Trad Tue, 04/19/2011 - 21:34
    2013 Small Business
Hi Mahesh,
I just found THIS whilst on the hunt for more info and figured it would be useful to you as well.
Cheers,
David.
mahesh101 Wed, 04/20/2011 - 00:10
Hi David
Does this mean I will have to wait until July to configure the Switched Properly or Will I be able to use CCA 3.0 (1) to configure the switch after the firmware update in May
Mahesh
David Harper Wed, 04/20/2011 - 00:49
  • Cisco Employee,
CCA support for these switches will not be until release 3.1 which as you say is around the middle of the year.  However, the actualy configuration requirements to get the switch working with a UC500/UC300 when you have the 1.1 firmware are pretty minimal, and of course you can always continue to use the switch web GUI for the interim few weeks.  That will not be going away at all.
Cheers,
Dave.
mahesh101 Wed, 04/20/2011 - 01:00
Hi David
If I update the Firmware on the Switch will I have to reconfigure the switch, or will I be able to restore the configuration if I backed it up.
Mahesh
David Harper Wed, 04/20/2011 - 17:36
  • Cisco Employee,
The configuration is retained through the upgrade, so there should be no need to backup and restore.  Obviously backing up befor
e an upgrade is good practice, but I haven't ever needed to restore a backup after an upgrade, and don't really expect I will need to in the future.
Cheers,
Dave.
David Harper Wed, 04/20/2011 - 00:50
  • Cisco Employee,
And I'd also like to say that there are way too many David's on this thread...
David Trad Wed, 04/20/2011 - 15:18
    2013 Small Business
OK OK I am going to go back into my sandbox....
mahesh101 Thu, 04/21/2011 - 02:41
I went to the Site and saw Call Forwarding was activated, for some reason call forwarding is being set automatically, is there anyway to disble call fowarding so it can't be activated.
Mahesh
David Trad Thu, 04/21/2011 - 03:11
    2013 Small Business
You could use CCA to remove the CFWall soft key from the ephone template, this prevent the phone from being able to do it , but of course this will effect every phone.
Or you could try and reeducate the staff in what to look for so they can keep am eye for it.
It is a common mistake with new installs and new users.
Cheers,
David.
Related Content
