GLC-GE-100FX= SFP in 2960S-24TS-L only running half-duplex
Answered Question
Apr 20th, 2011
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
We run a 100 Mbit trunk over 62.5 MM fiber to a remote building. We replaced the building’s single switch.
Old:
2950C-24 switch with integrated 100BASE-FX optic using a MTRJ to SC fiber patch
New:
2960S-24TS-L and GLC-GE-100FX= SFP optic with LC to SC fiber patch
Since the install, the link will only connect at half-duplex 100 Meg. It will not link when forced to full duplex. The other end is a 6324-100FX-MM module in our 6509. No duplex mismatch issues prior to the new switch, optic and patch. We measured only 4-5 dBm loss at each end point with our fiber owl. To rule out the fiber path, I duplicated the problem with an identical 2960 switch and optic over a 2-meter LC/LC patch to the 6509. I also tried a 2-meter LC/LC patch between these optics in the same 2960 switch, again only half-duplex.
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL632702.html
- suggests compatibility with the 2960S-24TS-L and the switch recognizes the SFP and appears to function normally other than the duplex issue.
Not sure why we seem to be stuck at half-duplex. Any thoughts or suggestions are much appreciated, thanks!
Correct Answer by Tom Randstrom about 6 years 3 months ago
Have you tried to "no duplex" on each end and then reset each end to "duplex auto" or "duplex full"?  You might also try to remove/reinsert the transceiver at the 6500 end and see if this clears the problem.
Very odd situation.
Overall Rating: 5 (1 ratings)
Correct Answer
Tom Randstrom Thu, 04/21/2011 - 07:00
  • Gold, 750 points or more
Very odd situation.
mrdorshimer Thu, 04/21/2011 - 07:32
so far so good...
"no duplex" followed by "duplex full" has worked on my test bench, from a 2960 to 6509 and between a pair of 2960's. I will test in production shortly and report back.
Update:
That suggestion works in production. Have you seen something similar before? I don't think I've ever had to "no duplex" a port/optic before it would run at auto or full properly.
Thanks!
