Uprading the License from IPbase to IPservices on 3750x Stack
Answered Question
Apr 26th, 2011
I need to enable the "IPservices" license on the 3750X stack. I used the below commands
3750-sw01(config)#license boot level ipservices switch 1
3750-sw01(config)#license boot level ipservices switch 2
When I do a "sh ver" I can see only switch 1 says "Next reload license Level: ipservices", not switch 2. Switch 2 specifies "Next reboot licensing Level   : ipbase".
When I session to switch 2, I can't go into config t mode to enter the above commands. I am not quite sure why config t mode fails.
3750-sw01-2#conf t
% Invalid input detected at '^' marker.
Nachi
Correct Answer by ranraju about 5 years 11 months ago
Do you get a "End User License Agreement" (EULA) when you type "license boot level ipservices switch 2"?
If you do then it actually displays a very long message, and in the end it asks you if you would like to ACCEPT? (yes/[no]): --- if you choose "yes", it means that you have accepted the EULA, and then it displays a message saying on the next reboot ipservices will be used.
If it doesn't display anything after you type "license boot level ipservices switch 2", i would suggest you to unstack the member switches and upgrade the license to ipservices individually and the stack the switches and see if it works.
ranraju
(TAC)
On the second switch in "Index 2", you see that the EULA is not accepted, which means that the evaluation license for ip services is not selected yet. Only when thats enabled, the show version would say that on its next reboot ipservices will be selected.
Overall Rating: 5 (6 ratings)
ranraju Tue, 04/26/2011 - 23:57
  • Cisco Employee,
Only the show and debug commands are available in a CLI session to a specific stack member. You cannot go to the config mode of the member switch when the switch is in the stack.
ranraju
Nachiappan Nach... Wed, 04/27/2011 - 00:08
Thanks.
So how can i upgrade the licenses on the stack member. The command excuted on the stack masterdoes not make changes on the stack member ?
ranraju Wed, 04/27/2011 - 00:14
  • Cisco Employee,
Can you paste the output for "show license detail switch 1" and "show license detail switch 2"...
Latchum Naidu Wed, 04/27/2011 - 00:26
  • Blue, 1500 points or more
Reload the switch after you upgrade the license level.
See the below for your information....
Mismatched or incompatible software license levels might prevent a Catalyst 3750E switch from joining a stack. These license levels are also called sets, or feature sets:
IP base (ipbase)
IP services (ipservices)
Advanced IP services (advanced ipservices)
Each member switch must have a compatible feature license. Otherwise, you need to upgrade the license level and then reload the switch.
To review the installed license in a member switch, enter these commands. In this example, member switches have the same license level:
Stack-1# show license all switch 1
License Store: Primary License Storage
StoreIndex: 0   Feature: advipservices
        License Type: Permanent
        License State: Active, In Use
Stack-1# show license all switch 2
A switch can have up to three installed licenses, but only one is active. Use the show version user EXEC command to see the active licenses. This example is part of the output message for one stack:
Stack-1# show version
Switch 03
License Level                   : advipservices
License Type                    : Permanent
Next reboot licensing Level     : advipservices
Switch 04
Please rate the helpfull posts.
Naidu.
Nachiappan Nach... Wed, 04/27/2011 - 00:36
Thanks.
Please find the requested details below:
3750-sw01#sh license detail switch 1
Index: 1        Feature: ipbase                            Version: 1.0
        License Priority: Medium
        License Count: Non-Counted
        Store Index: 0
        Store Name: Primary License Storage
Index: 2        Feature: ipservices                        Version: 1.0
        License Type: Evaluation
        License State: Active, Not in Use, EULA accepted
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
        License Priority: Low
        Store Index: 0
        Store Name: Evaluation License Storage
3750-sw01#sh license detail switch 2
        Store Index: 0
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
        Store Index: 0
Now I need to upgrade the license from "Ipbase" to "ipservice". So as i mentioned before i used the commands "license boot level ipservices switch 1" and "license boot level ipservices switch 2" on the master switch. After executing the commands i did "sh ver". The master switch specifies "Next reload license Level: ipservices" and the stack member specifies "Next reboot licensing Level: ipbase".I thought both switch should specify "Next relaod license level:ipservices".
Nachi
Latchum Naidu Wed, 04/27/2011 - 00:42
You need to reload the switch in order to take effect.
Naidu.
xavierkang Mon, 02/15/2016 - 20:51
Regarding to the command "license boot level ipservices", will it be extra charge to the client? Sorry,I'm newbie for network field. If yes, how should i close it? "no license boot level" ?
narmural Tue, 04/05/2016 - 06:00
  • Cisco Employee,
Please use the below command on the switch to accept EULA:
license right-to-use activate license-level acceptEULA
Naresh M
er.vansh17091 Tue, 02/21/2017 - 11:54
Hello Team,
Need a information about.
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.0(2)SE10, RELEASE SOFTWARE (fc2)
how to set switch3 to ipservices eval.
here switch 3 means Stack 3, Can you address me how to configure the and post configuration, have to reboot it ?
show license detail switch 3
        Store Index: 0
Index: 2        Feature: ipbase                            Version: 1.0
        License State: Inactive
            Period used: 0  minute  0  second
        Store Index: 2
        Store Name:
Index: 3        Feature: ipbase                            Version: 1.0
        License Type: PermanentRightToUse
        Store Index: 3
        Store Name:
Index: 4        Feature: ipservices                        Version: 1.0
            Evaluation period left: 7  weeks 3  days
            Period used: 1  week  0  day
            Expiry date: Apr 15 2017 16:39:57
        Store Index: 0
        Store Name:
Index: 5        Feature: ipservices                        Version: 1.0
        Store Index: 1
        Store Name:
ahakels Tue, 02/21/2017 - 20:56
  • Cisco Employee,
Step 1 : Log in to the switch by using the console port, the Ethernet management port, or a Telnet session.
Step 2 : copy license file onto the flash: device from the tftp server.
Step 3 : Install the license on the switch with the following command in the privilege mode:
                license install file-sys:file-sys//lic-location
               Once the license gets installed a log message similar to this should be seen:               "%IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Next reboot level = ipservices and License = ipservices"
Step 4 : The license is installed once you have accepted the EULA, but to enable the feature set after installing the license, you need to reload the device. Before reloading the device, the next license boot level of the switch has to be changed, use the following command to do so:
(In config mode) - license boot level license-level [switch switch-number]
On Stack use:
If the show license all command displays the license as "Active, Not in Use, EULA not accepted," you can use the license boot level command to enable the license and accept the end-user license agreement (EULA).
Step 5 : Verify if the new license was installed:
- show version | in License|license
Step 6 : check if the EULA is accepted or not from the command
show license detail
Step 7: to check the allowed features on the switch
show license feature
Correct Answer
ranraju Wed, 04/27/2011 - 00:46
  • Cisco Employee,
Nachiappan Nach... Wed, 04/27/2011 - 00:59
Thanks Ranraju.
I am not sure why the EULA is not accepted. The devices are brand new and i received them with the license file. I think i need to contact cisco.
Correct Answer
ranraju Wed, 04/27/2011 - 01:07
  • Cisco Employee,
ranraju
(TAC)
Nachiappan Nach... Wed, 04/27/2011 - 01:26
Thanks again.
No, i am not getting the prompt to "Accept" EULA. As you said i need to unstack the member and upgrade the license.
Nachiappan Nach... Wed, 04/27/2011 - 21:23
Thanks all.
I have installed the license and the device is running "ipservices".
Cheers
Nachi
ranraju Wed, 04/27/2011 - 22:03
  • Cisco Employee,
I am glad that it worked .
Cheers,
ranraju
(TAC)
Mahmoud Wed, 02/17/2016 - 16:53
hello
have the same issue , but my switches run universal ios now so do I need to download th ip base image then issue the license #boot level ipservices switch 1
but my base license shows permanent and ip services show evaluation
what is that mean?
