1811 Password Recovery / ROMMON issue
Answered Question
Apr 27th, 2011
Hi there,
Have a Cisco 1811 that I want to use for a lab but unable to get into it.
When it boots you get nothing on the console (e.g. no boot up indications) after a minute or so it presents:
Press RETURN to get started!
This drops me to the Router> prompt.
If I try to go into enable mode I get % No password is set
Have tried sending a break during boot to get to ROMMON but doesn't work......
Sho version gives me the following:
Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version 12.4(2)XA,
RELEASE SOFTWARE (fc3)
Synched to technology version 12.4(3.9)T
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Sun 09-Oct-05 22:05 by ealyon
ROM: System Bootstrap, Version 12.3(8r)YH6, RELEASE SOFTWARE (fc1)
ROM: Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version 12.4(
2)XA, RELEASE SOFTWARE (fc3)
Router uptime is 11 minutes
System image file is "flash:c181x-advipservicesk9-mz.124-2.XA.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 1811 (MPC8500) processor (revision 0x300) with 118784K/12288K bytes of mem
ory.
Processor board ID XXXXXXXXXXXXXX, with hardware revision 0000
10 FastEthernet interfaces
1 Serial interface
1 terminal line
31360K bytes of ATA CompactFlash (Read/Write)
Router>
Any ideas on how to reset/recover it?
Don't care about the existing config, just want to start afresh and its bugging me now!
Mike
Correct Answer by Latchum Naidu about 6 years 2 months ago
See the below link would help you...
http://www.cisco.com/en/US/products/hw/routers/ps221/products_password_recovery09186a0080094773.shtml
Please click on the correct answer if this answered your question.
Naidu.
Overall Rating: 5 (1 ratings)
garapoglou Wed, 04/27/2011 - 04:27
  • Bronze, 100 points or more
I don't think of a way to erase the current configuration without going into the privilege exec mode, other than the ROMMON.
Have you tried going into ROMMON on another PC or using another terminal utility?
Best regards,
Giorgos
Mike Bailey Wed, 04/27/2011 - 04:41
Have tried an XP laptop with Hyperterminal and CTRL+BREAK as well as a Windows 7 laptop with Putty and 'Send Break' neither can I get it into ROMMON
Mike Bailey Wed, 04/27/2011 - 05:02
Sorted....schoolboy error
Had already read the procedures but re-reading them noticed the 'aux port not active during boot'.
Now all my test kit is in a rack under my desk and I can't get to the ports on the rear so have cabled the console/aux ports of the ports on the back up to a patch panel on the front which I can then plug the console or patch cable into.
Double checked and I'd plugged it into the patch panel port cabled through to AUX - doh!
Swapped AUX/Console labels and now correctly plugged into Console and can break to ROMMON.
Thanks for suggestions!
garapoglou Wed, 04/27/2011 - 04:59
I'm pretty sure you know the combinations for the Break key, but have you tried pressing the Break key without holding Ctrl when using HyperTerminal?
Giorgos
cadet alain Wed, 04/27/2011 - 05:09
  • Purple, 4500 points or more
How are you connected to this router?
Regards.
Alain.
paolo bevilacqua Wed, 04/27/2011 - 05:00
  • Hall of Fame,
    Founding Member
There is a (small) chance that the console speed is set wrong in configuration-register, but OK in IOS config.
Try different speed settings to see if you can get output when booting the unit.
Latchum Naidu Wed, 04/27/2011 - 05:09
  • Blue, 1500 points or more
Hi Mike,
I am glad that me helped you....And thanks for your rating.
Naidu.
