Antonio Knox Thu, 04/28/2011 - 07:13
  • Silver, 250 points or more
Looks like 192.168.11.1 is your VPN gateway.  In this case you will need to NAT 192.168.10.0/24 to the address of your outside interface (traffic from 192.168.10.0/24 --> 192.168.11.1 will appear to be sourced from 192.168.11.2 here.
!----Define the gobal address (this will be, in this case, the existing address on the outside interface, which is perfectly doable any address in the 192.168.11.0/29 range (besides .1)will do , though)---
global (outside) 1 192.168.11.2
!----Define the traffic that will NAT to the global address when passing through the outside interface to the VPN gateway (192.168.10.0/24 --> 192.168.11.1)
access-list nat-to-vpn extemded permit ip 192.168.10.0 255.255.255.0 host 192.168.11.1
!---Apply interesting traffic to NAT
nat (inside) 1 access-list nat-to-vpn
Please rate helpful posts.
