Linksys SRW2024
Apr 27th, 2011
What kind of cable is required to connect to the Console on a Linksys SRW2024 switch ? ( I've lost the original cable )
I use the following settings: Speed 38400, 8 bits, no parity, no flow control and stop bits 1
I have tried a serial cable, no go.
I have tried a null modem cable with partial handshaking, no go.
I have tried a null modem cable with full handshaking, no go.
For the null modem cables, if I use it to connect between computers using hyperterminal it works very well. What I type on one computer appears on the other computer's screen.
However, I can't get anything out of the switch. I've tried pressing Enter repeatedly, resetting the switch with the Console cable on, etc.
Is it a special kind of cable for the console ?
David Carr Thu, 04/28/2011 - 05:35
George,
The console cable is the standard 9 prong female console cable.
When connecting via console, make sure the scroll lock is not enabled as that will freeze the curser and it will just blink and will not allow you to type or get into the switch.
mchokka1987 Mon, 05/09/2011 - 00:12
hi
i have swr2024 switch
i want a bandwidth consoldation like dis
i have 8 mbs connection
i want to control it as for 3 port as
2Mbs     2Mbs      2mbs
i the 2and3 port r nt in use 1port  should use full line 8mbs
how can i ?
plz rely me
Related Content
