04-27-2011 04:14 PM
Good Evening,
We are looking to enable to Marketing Email Settings in the Anti-Spam configuration. Instead of "Add Text to Subject", we want to add a X-Header to the e-mail. I see how to do this. My question is can I create a report in Ironport to show which e-mails this X-header was added too? We basically want to get an idea of how many of e-mails "hit" this rule.
Thanks in advance for the help!!
Doug
Solved! Go to Solution.
04-28-2011 10:46 AM
Hi Doug,
There is currently no built in reporting functionality that would provide any type of reporting on this data. You could however modify the log function using logconfig in the CLI so that it includes the header data. From there you could use something externally against the mail logs to generate these types of reports. I will be happy to create a feature request so that this functionality can be considered for inclusion in an up coming release of AsycnOS.
Christopher C Smith
CSE
Cisco IronPort Customer Support
04-28-2011 10:46 AM
Hi Doug,
Christopher C Smith
CSE
04-28-2011 10:53 AM
Christopher,
Thanks for the info. I will look into do this. Please create the feature request for this. I think that it would be helpful to other also.
I also thought about using the "Archive Message" option in the "Marketing Email settings". But I'm concerned about the diskspace that this archive might take up.
Doug
04-28-2011 09:12 PM
You can configure "logheaders" from cli and add your customized "X-header" to it.
It will create the log in bounces and mail_logs (maybe others too).
These logs are relatively small compare to archive the messages.
