Bandwidth control
Apr 29th, 2011
  I am needing to set up a 2801 router as a bandwidth controller.
My intention is only bandwidth control over IP address, no specific traffic. Until now I had some success but I'd like to know what is the  better way to do that.
Thats my configurations:
class-map match-any PQT
match access-group name Controla_banda
class-map match-any Cliente01
match access-group name cliente_teste
policy-map QoS
class PQT
   police rate 800000
interface FastEthernet0/1
description $ES_LAN$
ip address 172.16.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
service-policy output QoS
ip access-list extended Controla_banda
permit ip host 172.16.0.3 any
permit ip any host 172.16.0.3
ip access-list extended cliente_teste
permit ip host 172.16.0.4 any
permit ip any host 172.16.0.4
Any guidance will be very apreciated!
Thanks in advanced!!
Andre Albuquerque Fri, 04/29/2011 - 13:03
  • Cisco Employee,
It seems like you want to rate limit (police) the traffic from and to 172.16.0.3 to 800Kbps, on each direction, correct?
All other traffic will remain untouched (not limited).
If this is the objective, I would write the policy differently:
ip access-list extended TO_HOST1
ip access-list extended FROM_HOST1
class-map TO_HOST1
match access-group name TO_HOST1
class-map FROM_HOST1
match access-group name FROM_HOST1
policy-map OUT_QOS
class TO_HOST1
police 800000
policy-map IN_QOS
class FROM_HOST1
police 800000
int fa0/1
service-policy input IN_QOS
service-policy output OUT_QOS
Your configuration is limiting the traffic in only one direction (directed to 172.16.0.3).
HTH, Gustavo
Flavio Miranda Fri, 04/29/2011 - 20:39
Hi Andre,
  Thanks for your help ! I saw you are brasilian too, but let me keep writing in english for practice...I am needing!
About the post, one more questions. I have the intention of garantee 10 % of the traffic for each class-map...I mean...I have 1 Mb full and I'd like to divide it for "n" users and each one will have at least 10% available.
How can I perform it using the Policy ?
Thanks again and congratulations !!
Andre Albuquerque Mon, 05/02/2011 - 06:22
  • Cisco Employee,
You can guarantee bandwith with the command "bandwidth" on each class of a policy-map, specifying the amount of bandwidth to reserve in kbps.
You cannot configure bandwidth guarantees and policing in the same class though.
If you don't mind, I'd recommend you to read documentation and some books to better understand QoS theory.
There are some good documents on CCO:
- http://www.cisco.com/univercd/cc/td/doc/solution/esm/qossrnd.pdf
- http://www.cisco.com/en/US/docs/voice_ip_comm/cvd/G2srlgbrnt/FeatServ.html#wp1013051
- http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/12_4/qos_12_4_book.html
And some books:
- http://www.ciscopress.com/bookstore/product.asp?isbn=1587051761
- http://www.amazon.com/Deploying-MPLS-QoS-Multiservice-Networks/dp/0123705495
Cheers, Gustavo
