Troubleshooting Nac Guest Server Authentication Error
Apr 30th, 2011
Hello Everybody,
I installed NGS 2.0.2 for wireless guest user management and authentication. I implement webauth via webauth page on wlc deployed.
One Branch with a WLC5508 version 7.0 wireless anchor controller is working on the NGS.
But now I integrate next branch with WLC4402 version 6.0.188 and the authentication of users at the new branch gets an error, wrong user/password.
I double checked configuration and user/password but I can't find any configuration error. Also stopping and starting of radius service and reboot of NGS still does not help.
I tried to debug the radius via web interface and watched for the loggfile and there is still a reject.
I also tried the freeradius command radiusd -X but I got an error when starting the radiusd -X.
1.) How can I figure out, if I will get the correct password from my WLC ?
Are there any debug options to see more ? e.g. some cli commands, radiustest utilities or did someone know how to get the received password from the chap challenge of the debug ?
2.) I have appended a part from my radius loggfile. How can I find the detailed error in the radius loggfile ?
     Is it correct that the password in the debug file is empty ?
     raiuds logg line "[radius-user-auth] expand: %{User-Password} -> "
Best Regards
Alois
Vinay Sharma Mon, 05/09/2011 - 07:57
  • Gold, 750 points or more
Hi Alois,
This looks more a AAA related issue so moving it to AAA domain for faster response from Experts.
thanks,
Vinay
alois.heilmaier... Fri, 09/23/2011 - 04:21
updated WLC4402 to version 7.0.98.0, same version is on WLC5508.
But WLC4402 has the same problem for authentication, like with 6.0.188 again.
Any suggestions on this problem ?
Best Regards
Alois
alois.heilmaier... Tue, 12/27/2011 - 01:59
think I found the error.
Config guide for external web-auth showed radius-auth method is configurable.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008067489f.shtml
"config custom-web radiusauth "
Config guide of NGS has a small but important note:
http://www.cisco.com/en/US/docs/security/nac/guestserver/configuration_guide/20/g_radius.html
"NAC Guest Server supports only PAP in RADIUS Authentication"
So I checked my configurations (show custom-web all), and now I see the error.
Working controller has PAP authentication configured, failed controller has CHAP authentication configured.
I will change the congfiguration and test it, but I think that's the problem, because NGS does not support CHAP based authentication.
Best Regards
Alois
Related Content
