disable anyconnect autostart
Answered Question
May 3rd, 2011
Hi all
We use Win7 with anyconnect secure mobility client 3.0.0629.
Whenever I start my client anyconnect is started too and its icon appears in the system tray.
How can I disable the autostart of anyconnect secure mobility client?
Patrik
Correct Answer by mabazeed about 2 years 11 months ago
Hey Patrik,
Sorry I have few things that prevented me from checking your reply.
Anyhow, you can check this enhancement request that we have to intergrate the option that you are refering to: CSCtn12023, you can use the cisco bug tool kit to check this bug.
HTH, if it does then you can mark this post as answerd
Cheers,
Mo.
Average Rating: 5 (2 ratings)
mabazeed Thu, 05/05/2011 - 12:29
Try msconfig on windows run and uncheck the cisco AnyConnect secure mobility on the startup tab
patrik.spiess Thu, 05/05/2011 - 22:09
Ok, this might be a solution. Thanks.
BUT: I thought of an option in AnyConnect itself. The best way for us would be if we could install AnyConnect with automatic Windows start disabled by default.
If this is really not possible then I unfortunately have to accept your solution.
regards
Patrik
Correct Answer
mabazeed Sat, 05/07/2011 - 11:49
Hey Patrik,
Cheers,
Mo.
patrik.spiess Sun, 05/08/2011 - 22:15
Hi Mohammad
Thanks for your reply.
This enhancement request is exactly what we're waiting for.
regards
Patrik
Login or Register to take actions
Posted May 3, 2011 at 5:02 AM
Stats:
Replies:4 Avg. Rating:5
Views:10782 Votes:0
Shares:1
Categories: AnyConnect
Related Content
Discussions Leaderboard
