Configuration Professional
May 4th, 2011
I have Cisco 892 (CISCO892-K9) with trial version of IOS content filtering, which I would like to manage through Configuration Professional 2.5. The Express version works fine while CP version doesn't start. It stops when "Retrieving Port".
I changed some settings at Java menu, I also use DHCP server with 10.10.10.0/24 address range, I'm connected to port FE0 like it's said at Getting Started PDF and I use Win 7 with latest Java.
Could anyone help me?
Overall Rating: 4.7 (6 ratings)
Gregor Bizjak Wed, 05/04/2011 - 05:49
Found the solution thanx to "cadet alain" -> I just needed to read details - you need to "run as administrator", and then CP opens sucessfully.
