Nexus vPC load-balancing
We are having some issues with vPC load-balancing on our Nexus 5000 switches. The vPC consists of 1 interface on each 5000, but we are only seeing traffic sourced from nexus on one of the interfaces
Return traffic from our blade switches are utilizing both links.
part of running-config:
port-channel load-balance ethernet source-dest-ip invalid-hash
vpc domain 1
     peer-kepalive destination <snip>
interface port-channel 1
     switchport mode trunk
     vpc peer-link
     switchport trunk allowed vlan 1-90,92-4093
     spanning-tree port type network
interface port-channel 2
     vpc 2
we have 1 interface assigned to each channel-group. we have tested both lacp and static mode. Anyone else seen this type of behaviour?
-Jeppe
Marcel Zehnder Thu, 05/05/2011 - 05:23
Hello
Could you post some kind of network diagram? If I get you right the problem only occurs in the direction N5k --> Blade Switches: Maybe there's a problem one layer above (rest of LAN ---> N5k), like traffic is arriving only on one of your two N5k's?
-Marcel
