Guide for New CME 8.6 Install?
Answered Question
May 4th, 2011
I'm trying to get to CME 8.6 on a brand-spankin'-new 3945E.
The Install Guide is rather vague on how exactly to install CME of any version.  I would normally load the cme-basic-x.x.x.tar file to the router and be on my way.  However, 8.5 and 8.6 do not have this file on the software downloads site (I think 8.0 is the latest to have it).  If you download the .zip file and extract the contents, it's still not there.
Is the procedure to go 8.0 -> 8.6?  If so, what is the upgrade process?
Is there a direct install method?
Am I totally missing a basic concept here?
Thanks in advance...
Here's the directory that's extracted from the .zip:
7970-71-75-Background-readme-v1.txt
7970-71-75-backgroundsv1.tar
ata_03_02_04_sccp_090202_a.zip
ata_188_03_02_04_sccp_090202_a.zip
CME 8.6.0 GUI
cme-tsp-2.2.0.5.zip
cmterm-6901_6911-sccp.9-0-2-0.tar
cmterm-6901_6911-sccp.9-1-1-0.tar
cmterm-6921_41_61-sccp.9-1-1-0.tar
cmterm-7902G-sccp.8-0-2.tar
cmterm-7905G-sccp.8-0-3.tar
cmterm-7910-sccp.5-0-7.tar
cmterm-7911_7906-sccp.9-1-1SR1.tar
cmterm-7912G-sccp.8-0-4.tar
cmterm-7914-sccp.5-0-4.tar
cmterm-7915.1-0-4.tar
cmterm-7916.1-0-4.tar
cmterm-7931-sccp.9-1-1SR1.tar
cmterm-7935-sccp.3-2-9.tar
cmterm-7940-7960-sccp.8-1-2.tar
cmterm-7941_7961-sccp.9-1-1SR1.tar
cmterm-7941_7961-sip.9-1-1SR1.tar
cmterm-7942_7962-sccp.9-1-1SR1.tar
cmterm-7942_7962-sip.9-1-1SR1.tar
cmterm-7945_7965-sccp.9-1-1SR1.tar
cmterm-7945_7965-sip.9-1-1SR1.tar
cmterm-7970_7971-sccp.9-1-1SR1.tar
cmterm-7970_7971-sip.9-1-1SR1.tar
cmterm-7975-sccp.9-1-1SR1.tar
cmterm-7975-sip.9-1-1SR1.tar
cmterm-8961.9-1-1SR1.tar
cmterm-9951.9-1-1SR1.tar
cmterm-9971.9-1-1SR1.tar
cucme-mlpp.tar
music-on-hold.au
P0S3-08-9-00.tar
ringtones.tar
SCCP6921_41_61.9-0-3-b.tar
CME 8.6.0 GUI\admin_user.html
CME 8.6.0 GUI\admin_user.js
CME 8.6.0 GUI\CME_GUI_README.TXT
CME 8.6.0 GUI\dom.js
CME 8.6.0 GUI\ephone_admin.html
CME 8.6.0 GUI\normal_user.html
CME 8.6.0 GUI\normal_user.js
CME 8.6.0 GUI\telephony_service.html
CME 8.6.0 GUI\xml-test.html
CME 8.6.0 GUI\xml.template
Correct Answer by Michael Cole about 5 years 6 months ago
Have similar setup...2921 brand new with IOS 15.1-4M1...trying to get CME 8.6 loaded but am having same issue as Nick.  Also, the telephony-service setup command shows up as 'deprecated' for me and merely points me to cisco.com.  Is there something simple I am missing, or is it possible this was not ordered/licnesed correctly?
Hi Nick
To be perfectly honest, you don't actually need to load anything on the CME router to get things up and working.
CME is actually built into the IOS image, however you will have had to order the correct sofware package as you're running on a 3945E to be licensed to use it. 3945E will actually check that you're licensed when you start to define stuff.
If you just do a "telephony-service setup" command this just take you through the CLI set up wizard.
The files in your ZIP file are:
GUI files for CME (which personally I don't use as historically I've found it beyond buggy).
Firmware files for all the different phone types. These can be downloaded and installed invidually, as generally installations don't use each of the different phone types that Cisco produces.
Miscellanous files such as the MOH and Ring tone files.
In a nutshell, to get CME up and working, you don't need any of the above.
As a replacement to the CME GUI, you could also have a look at Cisco Configuration Assistant (CCA) which is available as a free download on CCO. IMHO it's much better than the old CME GUI anyway.
Hope this helps. Barry
Overall Rating: 5 (4 ratings)
Correct Answer
Hi Nick
Nick Richards Thu, 05/05/2011 - 14:44
Thanks, Barry.  You are 100% correct.
I have historically loaded the IOS, then installed the cme-basic tar for the version I wanted.  Apparently, that task is now deprecated and the files are all included w/IOS when you load the proper version.
Cheers,
NR
paolo bevilacqua Fri, 05/06/2011 - 01:40
  • Hall of Fame,
    Founding Member
[email protected]
Hi Nick
Barry has it 100%. Rated his post above.
Correct Answer
Michael Cole Thu, 10/13/2011 - 07:08
Nick Richards Thu, 10/13/2011 - 07:32
Oops, I had an errant click and rated your post as a correct answer.  I'll figure out how to change that...
Barry's post above was perfect and has a good recommendation to use CCA for configuration rather than GUI, and I found that Config Pro was stellar for the straight-forward config tasks.
I never got the "telephony-service setup" command to work, but I believe was able to just start entering parameters into telephony-service config mode.  Can you perform any of the tasks in this link?:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesystm.html#wp1023245
iantra123 Tue, 12/13/2011 - 07:45
I though it will be a nice GUI because it's a v8.6.
But at last the GUI is still like the version 4
Related Content
