Setting up a Second VPN connection
May 4th, 2011
I have multiple offices that I want to vpn into one office....  So is there anything special I have to do to establish this....Or can i do the same set up for one office then copy those setting to the next office?
Office 1 - main office .........asa 5510......ip 111.111.111.111
Office 2 - remote office......asa 5505......ip  222.222.222.222
Office 3 - remote office......asa 5505......ip 333.3333.333.333
I want office 2 and 3 to be able to vpn into office 1.
Currently I have already set up the vpn connection for office 2 to office 1.  Everything works well with that so I know it is good!
So could I basicly copy those setting to office 3?  Or is there some weird settings or anything I should do or avoid by now setting out office 3 to vpn into office 1??
Thanks!!
Yudong Wu Wed, 05/04/2011 - 15:22
  • Gold, 750 points or more
You can just use the same way as what you currently used for site 2 to configure the vpn for site 3 if you don't have the overlapped IP in site 3.
